Acousticaly Tuned?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=41717
Printed Date: May 13, 2026 at 11:47 PM
Topic: Acousticaly Tuned?
Posted By: lolzitsmtss
Subject: Acousticaly Tuned?
Date Posted: October 26, 2004 at 9:25 PM
How do you make your vehicle Acousticaly Tuned?
I guess that guy has subs.
Posted By: Rushman
Date Posted: October 26, 2004 at 10:50 PM
lots of dampening material , lots of research and trial and error. Lots of money (ha-ha) no really , lots of money. Knowing where to place speakers in relation to the drivers seat. Too many extra's to add.
99 F-one fitty
Pioneer Premier H/U
Alpine EQ
Kicker 1200 amp
4 Kicker comp 10s
6 kicker SS65.2 components
Posted By: vdubmk4
Date Posted: October 26, 2004 at 11:10 PM
When you say acoustically tuned, are you refering to your system being tuned correctly or you car behind turned into a concert hall ?
Fortune: You will continue to take chances, and be glad you did.
Date Posted: October 27, 2004 at 8:36 AM
The car into a concert hall.
Date Posted: October 27, 2004 at 8:37 AM
"lots of dampening material , lots of research and trial and error. Lots of money (ha-ha) no really , lots of money. Knowing where to place speakers in relation to the drivers seat. Too many extra's to add. "
So the New GMC Envoy has Dampening material all over the car? and alot more speakers then standard cars?
Posted By: DYohn
Date Posted: October 27, 2004 at 10:14 AM
You'll need access to an anechoic chamber, rollers for your driven wheels so you can simulate running at highway speed, a wind tunnel, several calibrated pink noise sources, several channels of RTA and calibrated microphones, several strain gages and vibrational/velocity transducers, a good oxy-acetylene torch and a better tig welder, sheet metal, access to a variety of different interior treatment materials like fabrics, carpets, seat covers, etc., lots of sound dampening materials, better seals and gaskets for all windows, and lots of time and patience.  It might also help if you had access to an acoustical engineer.  Then, after you solve all the issues with the vehicle's construction, you can begin to choose your sound system components.
Posted By: Rushman
Date Posted: October 27, 2004 at 11:04 AM
I think I know where your going with this lolzitsmtss.........Does this have anything to do with the GMC commercial on TV? Where they ask if a concert hall can be accousticly tuned , then why cant your truck? If a 60,000 seat stadium can have a retractable roof , then why cant your truck? If an offraod Baja 1000 racer can have 4 wheel active suspension , then why cant your truck?
99 F-one fitty
Pioneer Premier H/U
Alpine EQ
Kicker 1200 amp
4 Kicker comp 10s
Posted By: DYohn
Date Posted: October 27, 2004 at 11:25 AM
... and the real answer to those questions are corporate profits, weight, and CAFE standards.  It is a clever commercial, though.
Date Posted: October 28, 2004 at 2:07 PM
Yeah rushman..exactly. Saw the commericial and thought..How the hell can they do that?
P.S Dyohn..whats the best sound deadning material that you would say is the best....according to your preference?
Posted By: DYohn
Date Posted: October 28, 2004 at 3:04 PM
Dynamat, Brown Bread, Dayton, Gator Skin, generic no-name... In my experience it all functions pretty much the same as long as you take the time to remove the car's interior treatments and properly install it.  I say use what's available the cheapest in your area.  Actually you can use just about anything that will reduce structural resonance.  I've seen good results using standard home carpet pad, wool blankets, foam rubber, roofing tar....
Date Posted: October 28, 2004 at 4:33 PM
you know what....I tried looking up what else would stop or reduce the resonance or just the vibrating and i couldn't find anything.  I think the cheapest thing for me is home depot. I'se seen stuff its likes paint and u brush it on. It also comes in in a spray can and u just spray it on the object. I thought that was the best just spray it. I would think thats the easiest way. No roller no heat gun no nothing just spray. Also, Not to sound like a complete moron or idiot for asking this question...Can i spray the outside of the car? It goes on clear and odorless, its waterproof. Im thinking it must leave some kind of coating. I'll be sure to read the cautions and warnings about what it could do to the paint but if everything is okay and it doesnt leave any mark or anything visible..Will it actually work...have you had anyone actually do this?
Thanx alot man...I really appreciate you reponses...
thanx again
Posted By: Rushman
Date Posted: October 28, 2004 at 5:13 PM
Im not exactly sure what this spray on product is but if its some kind of sound dampening material or anything like it , Im sure it cant be good for the paint job. Im thinking the spray has adhesive or bonding qualities that might dry clear but still change the apperance of the car. Ive seen lots of people recently do the Rhino Lining all over the exterior of the vehicle but that was knowing the textured look it would produce. Did a good job on noise kill tho.....
99 F-one fitty
Pioneer Premier H/U
Alpine EQ
Kicker 1200 amp
4 Kicker comp 10s
Date Posted: October 28, 2004 at 6:54 PM
yeah, i kinda figured that
Posted By: Poormanq45
Date Posted: October 28, 2004 at 10:07 PM
For sound deadning, I usually use thick carpet. I have glued this stuff in the doors before. It works very well, and it's cheap. Also, it helps to spray the insides of body panels with rubber. This keeps them from vibrating much.
I have also had success using fiberglass insulation. I stuffed it into the doors. Also, the added insulation helped to maintain the temperature of the interior.
Basically, anything that is very porous will work good for sound deadning.
