SPLITTERS FOR TWO AMPS
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=41743
Printed Date: May 13, 2026 at 11:14 AM
Topic: SPLITTERS FOR TWO AMPS
Posted By: jdsoldno7
Subject: SPLITTERS FOR TWO AMPS
Date Posted: October 27, 2004 at 11:41 AM
should i run a splitter for two amps, a 800watt and a 200watt, one for subs one for mids, the splitter i have takes one power wire and splits to 2, of course, it is a fused splitter, with two fuses,
will this take power from one amp, and not supply enough power to the 800watt, to push the subs, or it will probally drain the batt, and alternater too? should i run the (batt)power to the amp, and then run (amp) power to the other amp?, or is that series wiring, if some one could touch up on this for me i'd greatly appreciate it
what about runing the (batt)power, to splitter, then power to 200watt, and power to a capacitor to keep a good current on the 800watt for the subs
will this hurt anything, or is there any pointers for this instalation
Posted By: DYohn
Date Posted: October 27, 2004 at 2:18 PM
Are you talking about a distribution block?  They are designed to split power to multiple loads (like amps.)  Just be sure your total load does not overload the current carrying capacity of the main power cable between the battery and the block (and be sure to add a properly rated fuse at the battery.)
Posted By: jeffchilcott
Date Posted: October 27, 2004 at 5:16 PM
distro- blocks do not make less power go to either amp, they will provied what the amp is drawing and like dyohn said the fuse will have to match the fuse on the amp.
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Date Posted: October 28, 2004 at 1:32 PM
thank you for the information. the 800wt has 2 15amp fuses, and the 200wt, has a 20amp, so i would it be safe to put a 30amp, in the fuse holder at the battery? the block must be after the first fuse holder, but does it have to be a certain distance, like per say 3 foot from the first fuse. i had a pic but it wont fit.
the capacitor?, would that keep the strain off my alternator, and save my battery, or what do yall think about a battery in the trunk, the gel ones?
Posted By: jon02accord
Date Posted: October 28, 2004 at 4:52 PM
dood, there is no way your amp with two 15amp fuses pushed out 800watts. that thing is waaaay overrated.
P= E x I
Power  = voltage X current
if your car's electrical system max voltage is 14.4volts and you have 30amps of protection the max power is 432watts.
https://www.the12volt.com/ohm/page2.asp
even at 2/3s of the fuse rating, which would be 20amps, your wattage would only be 288watts.
(someone correct me if i am wrong)
Posted By: stevdart
Date Posted: October 28, 2004 at 6:46 PM
jdsoldno7, add up the fuses in the amplifiers and you get 50 amperes.  The power wire should be at least 8 gauge (preferably 4 ga.), and a fuse of at least 50 amps in a fusenolder within a foot of the battery.  Power wire runs back to the area where the amps are to be installed.  The distro block is placed near the amps, with 8 gauge wire out to each amp.  The distro should have fuseholders built into it to fuse the two outgoing wires, you can use about 30 or 40 amps for each one.
As for the stiffening cap, I would suggest you try out the system before you install it....for the chance that you can return it and spend the money on more necessary stuff like sound damping.  If you do want to use it or feel it is necessary, place it in line between the distro block and the subwoofer amp, directly before the amp.
If I were a salesman in the field and made my pay on commissions, you can bet that everybody who left my store with an amplifier also had a cap!  But I'm not, and so I advise to find out first if your system actually could benefit from it.  It's an easy add-on.
Posted By: stevdart
Date Posted: October 28, 2004 at 7:12 PM
jon02accord,  I hear that often but it's not correct.  You are talking about finding Power, which in this case is watts from the speakers.  The voltage you used is the car's electrical system voltage, where to find power you would need to use the voltage output of the amplifier.
The job of an amplifier is to make voltage, after all.
The fuses on an amp are there to limit incoming amperage, and must not be confused with the amperage that the amplifier produces.   The input to the amp is low voltage, high current.  The output is high voltage, low current.
Since the amplifier makes volts, and P = E X I, then the power would come from the amp's output voltage times the current it produces which is determined by the load.
An example:  a USacoustics USB600D mono class D amp has a fuse of 20 amps.  It outputs 200 watts into 4 ohms, and 350 watts into 2 ohms.  By your reckoning, the maximum power output of this amp would be 288 watts, using your formula of 14.4 volts X 20 amps.  Your guess is way off track.  I have measured this particular amp and know its rating is accurate, but you can use any known amplifier and find the error in your reasoning.
Just for info:  Class D amps are much more efficient than class A/B amps and so would need less amperage in the fuses.  Their efficiency allows them to make more voltage with less amperage input, so the fuse rating can't be used to tell much.  And a class A amp, being even less efficient than A/B, will have a larger fuse rating than either of the above...for the same power output.  This makes you realize that the amp's fuse rating has little to do with the power a speaker will ultimately get.
Date Posted: October 29, 2004 at 8:15 AM
then why are amps rated in watts, which are completely subjective (overrated/underrated) and instead use voltage output of the amps. why is the industry standard based on watts, when according to your post, the actual measurement is voltage? and not just for the amps, how about the same for the speakers, instead of saying for example, speaker A can take 300watts RMS and 600 watts Peak when it should be some number measured in volts? should we also not rate light bulbs as 60watt, 75watt, and instead measure them in volts? with this field based on science and numbers, why is there so much subjectiveness in the rating systems of amps by different manufacturers?
Posted By: stevdart
Date Posted: October 29, 2004 at 12:18 PM
The actual measurement is not voltage.  Voltage is the difference of potential and doesn't equate to power until it meets a resistive load.  What is the resistive load on an amplifier?  The speakers, at a given impedance load.  So "watts" is all proper to use when talking about what an amplifier will do.  It is the load of resistance on the amp that causes it to make the watts.
You see that when a manufacturer gives a rating for an amplifier, it is given as so many watts into a load of impedance, such as 400 watts @ 2 ohms.  You have the amplifier and the connected speaker(s) combined to get to that.  And yes, there is quite a bit of subjectivity in the industry.  Notice how all power ratings of amplifiers end in even numbers?  75, 150, 400, etc.  What's the chances that every amp has been lab tested and the results always ended up at an even number?  None, of course.
But you understand that the amp fuse ratings do not correspond to it's power output, don't you?  It can be used as a "ballpark guideline", if you have enough experience with amps and have installed enough and tested enough of them to tell.  But it doesn't work in a simple E x I Ohm's formula.  If someone were to guess ballpark, first he has to know the amp's efficiency, which means some of the power is let off as heat.  He would guess the different types of amplifiers using somewhat different criteria.
In this thread, the "800 watts" spoken about had nothing to do with the intent of the question, and so it was not necessary to comment on.  Everybody knows nowadays that a lot of amps are advertised at power ratings  they could only hope to achieve in one millisecond when the solar system is perfectly alligned.  I'm not jumping on you for commenting, but just saying that I wouldn't in this particular subject, as it had no bearing on the question.  My comment to you was to make you (and others) more aware that judging the power an amplifier can make goes far beyond using a simple E x I formula using the car's voltage and the amp's fuses.
Date Posted: October 29, 2004 at 12:47 PM
no harm no faul, i dont feel that you jumping on me, and i wasnt attempting to flame the 800watt remark either. i can tell you that for some reason both my amps (one of which is an alpine 4ch and the other is a mtx d-class mono) seem to have a wattage output pretty close to 2/3 of the fuse rating. maybe just ironic, i dont know.
and i appreciate you commenting in regards to my asking to be corrected. :)
Date Posted: November 02, 2004 at 3:32 PM
thanks for the info, i didnt mean the total output, that is the peak of the amp, which i know dont mean alot, it is a viberant lanzar 418, this is the rating, it is a 4-channel, the speakers are rated 4ohms, so if i bridged the two speakers to the 4 channels, + & - on both terminals, it should give me a what load(ohms)?
  • 4 x 100 Watts RMS at 4 Ohms
  • 4 x 200 Watts Max at 4 Ohms
  • 2 x 400 Watts Max at 4 Ohms Bridged
  • 4 x 175 Watts at 2 Ohms
  • Posted By: stevdart
    Date Posted: November 02, 2004 at 8:32 PM
    Use the RMS rating as your guide...4 x 100 Watts RMS at 4 Ohms / 4 x 175 Watts at 2 Ohms .  If you were to bridge a 4 ohm load ( one sub ) onto channels 1 and 2, the load would be 4 ohm bridged.  That is equivalent to the 2 ohm rating because bridging a 4 ohm load is in effect putting a 2 ohm load onto each channel.  You see that the 2 ohm rating for this amp is 175 watts per channel at 2 ohms.  So the sub should get 2 X 175 = 350 watts.
    Do the same thing for the second sub onto channels 3 and 4, and each sub should get 350 watts, combined for 700 watts.  According to the rated specs.
    Now this is where the guesswork of real power output is guessed at.  The amp is a class A/B with an efficiency of 50 - 55%.  You would look at other known amps of the same type and do a quick comparison.....no math required.  And you would expect that an amp with factory-supplied fuses of that size would indicate that the amp has a true RMS output of about 4 X 45 watts @ 4 ohms, or 4 X 75 watts @ 2 ohms.  So a more realistic guess as to what each sub would actually get in watts would be 150 watts each.
    The key for an installation, especially with a suspect-rated amp, is to set the gains on the amp carefully.  Don't allow any distorted sound from those woofers when you are playing your system at full tilt, so that means don't use the amp gains to get more decibels if you think they're not loud enough.
    Which means, as I look at it, that I am pretty much in concurrence with jon02accord on the guess of the output of this particular amp.......although I would bump it up a little.  But you know, you can get it set up just right with no distortion/clipping, then get someone to do a reading of the output voltage and you'll know what the output is.  You could do that yourself, too, later on if you feel the need.  We have posted info for such a task here in the forum.  Who knows?  The guesswork might be way wrong and you're reallly getting 200 to 250 watts to each sub.
    Posted By: haemphyst
    Date Posted: November 03, 2004 at 12:09 AM
    Stevdart, you have usually been pretty right-on with most of your posts, but I gotta say this time you are indeed OFF!!! He was not confusing the input current rating with the output current capability. An amplifier can only CONVERT energy, not CREATE it. If your fuses limit your INPUT power to 288 watts, YOU CANNOT GET MORE THAN THAT OUT OF IT!!! (...on a continuous basis, anyway - read: 1000 watts, one channel driven, 4 ohm resistive load, 1kHz tone, 10ms, 50% THD - see the manufacturers data sheet on any Pyrabossenhag amplifier.) Additionally, you are limited by physics and the laws of thermodynamics to a given efficiency - how much is blown off as wasted, unusable heat? A standard class AB amplifer can reach a theoretical maximum of 66%, meaning for the power put in, 33% WILL GO AWAY AS HEAT! A 60% efficiency rating is more than accurate today. (Pure class A amplifers fall around 25% efficient, and most digital amps land around 90-94%.) In regards to digital amplifiers, just because they are more efficient, it still does not mean they can EVER break one hundred percent (put out more than is put in) I appreciate the fact that you may have measured that amp, but if you do the math yourself, then 288/200=69.4% efficiency. Pretty low for a decent digital amp, loaded with a 4 ohm driver, but still PERFECTLY BELIEVEABLE as an output rating into 4 ohms. As far as the 350 watts into 2 ohms, it is probable that the amp can indeed do it, for short periods of time, but on a CONTINUOUS, SINE WAVE BASIS, it cannot - it is simply impossible. Likely, even if we give the same amp the benefit of the doubt, and call it 95% efficient into 2 ohms, you will still only be able to get 288*.95=273.6 watts CONTINUOUS. The 350 watt rating into 2 ohms is only a 28% over-rating in regards to the input capacity, and ANY amplifier worth it's salt (meaning, built with a respectable power supply) will be able to maintain a 28% peak/continuous output ratio - that is called headroom - in this case, about 1dB of headroom.
    The POWER a speaker sees delivered to it is a function of voltage times current - you know that. A power amplifier is a voltage source, meaning it will try to make current as long as it can to see that the load always gets the same voltage. Translation: Lower impedance (2 ohms vice 4 ohms) higher current output. THIS is where power is made. The voltage output of a typical amplifier will always try to remain the same, regardless of the load placed across the terminals. The power supply simply reacts by making more current. (I really forgot where I was going with this...........oh, yeah) This is why you see few amplifiers that actually double their power outputs all the way down to their MAXIMUM LOADS. 4 ohms 100 watts SHOULD BE - 2 ohms 200 watts, right? Ohm's Law says "YES". Why are so many amplifiers rated 150 or 175 watts at 2 ohms? (or if they are rated as such, they likely won't be rated 400 watts into 1 ohm) Because their power supply is not "stiff" enough to make the current necessary to PROVIDE 200 watts at that impedance.
    I'm on jon02accord's side - He's right. Those amps are WAAAYYY overrated.
    Posted By: stevdart
    Date Posted: November 03, 2004 at 8:27 AM
    I think I understand that now, haemphyst.  Thanks for the heads up.  The amp I mentioned claims >90% efficiency, so if I say:  14 volts (car) * 20 amp (fuse) = 280, * 90% (efficiency) = 252 watts.  That's below the rated power output of 300 watts into 2 ohms.  The fuse is the tell-all that lets me know that the amp will never be able to get to that level in RMS watts and still be within the 0.3% THD rating.   Although 0.3% is the number for "rated power" which I guess is only applicable to the 4 ohm load rating.
