95 altima: error in the wiring database?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=41844
Printed Date: May 12, 2026 at 10:09 AM
Topic: 95 altima: error in the wiring database?
Posted By: toyota_4runner
Subject: 95 altima: error in the wiring database?
Date Posted: October 28, 2004 at 7:20 PM
Hello, according to the wiring database on this site the constant + is pink and switched + is blue. There is already a pink and blue wire for speakers, and there are no other pink. Is it possible there is an error in the database?
Also Nissan Altima owners might be able to help me with a question on alarm I posted recently in the security forum
THanks,
Alpesh
Posted By: tbirdman74
Date Posted: October 28, 2004 at 8:16 PM
Check and see if there is an org/grn wire for the 12v+ constant. the info i have for general nissan gives that for the wire color, and blu for the Acc wire. Hope this helps.
------------- If it don't fit, Force it.
If it breaks, You needed a new one anyway!
Posted By: chrane
Date Posted: October 28, 2004 at 8:58 PM
error in the wiring diagram,,, phhhh never.... bullsh*t, i was installing a 'factory' 2004/2005 dodge ram diesel remote start in a 2004 dodge ram diesel... the tach wire was suposed to be DARK BLUE/GREY... after testing all wires in a 60 pin connector found out it was red.
------------- Aaron
