2002 Cavalier Factory Amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=41861
Printed Date: May 12, 2026 at 5:36 AM
Topic: 2002 Cavalier Factory Amp
Posted By: RKNIGHTDMD
Subject: 2002 Cavalier Factory Amp
Date Posted: October 29, 2004 at 12:35 AM
I was wondering if someone could help me.  I recently purchased a 2002 Cavalier and the stereo will not work.  The head unit has power, but now sound at all.  The previous owner had a stereo system installed in the car and they may have neglected to reconnect something when they reinstalled the factory unit.  I have heard that if they didn't reconnect the factory amp, then the stereo would not work.  I can't even find the factory amp, so I can't check it out.  If anyone could tell me where the amp is located, I would greatly appreciate it.  Any advice you could give, I could use!
Thanks,
Richard Knight
Posted By: auex
Date Posted: October 29, 2004 at 1:08 AM
I wasn't aware that they had one.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: forbidden
Date Posted: October 29, 2004 at 1:28 AM
My bet, no speakers or speaker not connected.
Posted By: thepencil
Date Posted: October 29, 2004 at 9:17 AM
There is no factory amp on this car. Only class 2 system.
I am thinking the factory head unit may or maynot be working so I would start there. But the easier way is the speaker connection. As forbidden said, check your speakers and speaker connections, then proceed go to the factory head unit and check there.
Be careful whose advice you buy, but be patient with those who supply it.posted_image
Date Posted: October 29, 2004 at 9:24 AM
Thanks.  The speakers are all still in the car and the connections are good to the speakers.  I guess that I will have to take it to the sound shop to get it seen about.  Thanks for your help.
Ricky
Posted By: raydawg357
Date Posted: October 29, 2004 at 1:19 PM
There's either no output from your HU or your speakers are blown.
Do it right the first time
Posted By: Db160
Date Posted: October 30, 2004 at 1:49 PM
check out your speakers by popping them with a 9 volt battery.If they move fine in reverse and normal polarity then your problem lies elsewhere
John Bennett
2000 Michigan Points Champ
2000 World finalist (dB Drag)
Retired until I hit the lotto
