Amp / HU dilema
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=42109
Printed Date: May 10, 2026 at 5:12 PM
Topic: Amp / HU dilema
Posted By: paul167
Subject: Amp / HU dilema
Date Posted: November 02, 2004 at 12:42 PM
Hi
So I'm just in the process of upgrading my car system in my Golf III and I've come to the point where I have to worry about my audio install.
Right now I have 2 sony x-plod 17cm 170W peak (30W RMS) speakers and 2 pionneer 10cm 110W peak (20W RMS). My HU is a JVC 45Wx4, although if I got it right, that CAN'T be 45W RMS from an HU right ? Would anyone know how much that would approximatively be in RMS ?
As soon as I try to crank it up a little, the sound gets crappy. So until now I wasn't sure why that was, but my theory now is that my HU is to weak and I'm experiencing clipping as I've read up in some other thread. Basically, when loud, it sounds "saturated" and kinda "crispy", its hard to explain.
Could it really be clipping ? Seems weird seeing how my speakers are really not that powerful. If it isn't, what else might it be ?
If it IS clipping I am experiencing I understand I have to get myself a decent amp and it should fix it. What kinda power would I be needing here ? Something small around 30W RMS like my speakers ?
If I do get one, do you think I would have some decent sound or are my speakers just plain to weak ? When I say decent sound, I mean nothing very loud.
Also, isn't there a way of getting a more powerful HU ? It would really simplify the wiring :)
Anyhow, if anyone has any input on that, it would be greatly appreciated !
Paul
Posted By: bullman96
Date Posted: November 02, 2004 at 1:02 PM
all internal amps on decks usually suck pretty bad, so i would suggest getting an amp just for the doors speaks. you could probably find a 25x4 wattrms for pretty cheap that will sound good. how much are you will to spend if you go in this direction? we have a different idea of decent sound probably, so to check if it is your deck that is the problem try fading the speakers all the way to the front giving the front ones a bit more juice and then to the back giving the rears a bit more juice. also try turing down the bass and trying to go higher, if you hear any audible difference your speakers are probably capable of more. the deck probably puts out 20wx4rms at the most.
Posted By: raydawg357
Date Posted: November 02, 2004 at 2:22 PM
Make sure your speakers are all in phase.  Out of phase speakers also sound like crap.
Do it right the first time
Posted By: civicnut
Date Posted: November 02, 2004 at 2:37 PM
hi there i sugest get rid of the sony's and get external amp garenteed result . even a cheap amp
Posted By: paul167
Date Posted: November 02, 2004 at 2:39 PM
I guess I was hoping for something in the area of 100/150$.
I tried the fading thing, and it gets crappy on both my sony 30W door speakers and the small 20W on the console. I played around with the bass / treble, it seems the higher tones are fine. When i put more bass in, it starts to saturate more.
I really have very little bass, is an amplifier going to help with that at all (i.e. without a sub) ?
Also funny thing, my sister also has a Golf III which is 1 year younger though (-> 1993) and she has way more bass than I do. Her setup is pretty much the factory one, except for a new sony HU. She doesn't have an amp or sub or anything, just 10cm speakers in the console and 16cm ones in the doors.
How come her bass is that much better although she has apparently the same basic configuration than mine ? Could it be that she has "bass optimized" speakers ?
I thought the only way to improve your bass is to hook up a sub to an amp.
Thanks !
Paul
Date Posted: November 02, 2004 at 2:40 PM
still sounds like your speakers are out of phase.
Posted By: paul167
Date Posted: November 02, 2004 at 2:45 PM
Okay, I'm not exactly sure what that means, "out of phase speakers" ? :)
Posted By: civicnut
Date Posted: November 02, 2004 at 2:47 PM
ray is probably right then but i still recomend replacing the sony's
Posted By: paul167
Date Posted: November 02, 2004 at 2:48 PM
What's wrong with the sony's ? Are they known to be crappy speakers ?
Posted By: civicnut
your + & - are round the rong way
Date Posted: November 02, 2004 at 2:49 PM
Out of phase means you have the speaker wires crossed.   (-)'s are connected to (+)'s
Posted By: civicnut
Date Posted: November 02, 2004 at 2:51 PM
put it this way, you can get a lot better for your money!
Posted By: paul167
Date Posted: November 02, 2004 at 2:53 PM
okay well thanks guys im gonna go check out this phase thing for now !
Posted By: paul167
Date Posted: November 02, 2004 at 3:39 PM
So I tried inversing the polarity on the left door speaker and I didn't really notice any difference. After a little bit of listenning I noticed it's really note the amount of bass that is to low, its the quality of the bass. You see when I set the volume / bass higher the bass starts to sound ugly; I get a vibration in the bass sound, and not the clean heavy backfround sound it should have.
Could it be that the door speakers are not properly fixed / isolated ? I had them built in by a auto mechanic so I guess he should have done his job well ?
Or is this a HU problem and something thaht would be fixed with an amp ?
thanks
Paul
Posted By: audiobass10
Date Posted: November 02, 2004 at 3:46 PM
Honestly even when those speakers are performing at their best..they wont be very good. I'm not a big fan of pioneer either. I would suggest atleats getting rid of the Sony's. Yes they are generally considered a bad speaker. Heres a list that might be helpful to you or anyone else brand new to the car audio world. Its from another forum that I am on.
This is the infamous Good, Bad, and Ugly list.
These are some pretty generalized groupings and also very subjective. We've simply based our experiences with the products whether they are direct installs, personal property or extensive research. You should always physically listen to a product before purchase because you are the one who will determine whether or not an item "sounds good" or not.
This topic, while being controversial, is simply a generalized guide meant for beginners in the hobby. Many brands specialize in certain items, ie. better amplifiers than speakers, better mids than subs, etc... Also almost all manufacturers offer entry level products as well as high quality lines. As I stated before, this is a GENERALIZED guide. It is your responsiblity to research and audition every brand before you purchase anything. Good luck with your decisions.
We've broken this section into 4 catagories:
1: Bad
2: Questionable
3: Good
4: Highly Recommended
Bad
American HiFi (Rockwood)
American Pro
Audiovox
Automobile
Becker
Boss
DHD
JDL
Jensen
Kenwood (speakers)
Kole
Kraco
Kronik
LA Sound
Legacy
MA Audio
Optimus (Radio Shack)
Planet Audio (Boss, by any other name)
Power Acoustik
Profile
Pyle
Pyramid
Rockwood
SAS Bazooka (amplifiers)
Sherwood
Sony (anything by Sony)
Sound Storm
Sparkomatic
SPL Audio
Thump
Ultimate Sounds
Visonik
Volfenhag
Questionable
Alpine (lower model speakers)
Autotek
Audiobahn
Blaupunkt
Aiwa
Crunch
Elemental Designs (eD)
Hifonics
Hollywood
Kenwood (amplifiers, head units)
Kicker Solobaric (L5, L7, Solo-X square subs)
Lanzar
Lightning Audio
Matsui
MTX (subs)
Onyx Mobile Audio
Panasonic
Phoenix Gold (ask on specific models)
Pioneer (amplifiers and speakers)
Precision Power (PPI) (newer non-US made amplifiers)
Rockford Fosgate (current products)
SAS Bazooka (all products)
Good
Alpine (amplifiers, Type-R speakers and subs)
Altec Lansing
Alumapro
Ample Audio
Audio Development
Avionixx
Boston Acoustics
Cadence (current amplifier products)
Cerwin Vega (subs)
Clarion (head units)
Coustic
Crossfire
Crystal
Directed (DEI)
Earthquake
Eaton
Helix
Illusion
Infinity
JBL (amplifiers)
JVC Digifine
Kicker (amplifiers & Comp/CompVR subwoofers)
Lunar
Memphis Audio
MTX (amplifiers)
Phoenix Gold (some models)
Polk Audio
Rockford Fosgate (some models)
Soundstream
USAcoustics
Highly Recommended
a/d/s
Adire
Alpine (head units, signal processors)
Arc Audio
Audax
Audio Control
Brax
Butler Audio
CD Technologies (CDT)
Diamond Audio
Digital Designs (DD)
DLS
DynAudio
Eclipse (Fujitsu Ten)
Esoteric Audio
Focal
Harrison Labs
Image Dynamics (ID)
Infinity Kappa/Kappa Perfect components
JL Audio (subs, XR components, slash series amps)
KEF Kar components
Kove
Luxman
MB Quart
McIntosh Laboratories
MMATS
Morel
Nakamichi (tape transports)
Ohio Alternator
Orion
OZ Audio
Pioneer Premiere (head units)
Precision Power (PPI) (Art series amps, old)
Rainbow
Resonant Engineering (RE)
Rockford Fosgate (older 1980s and 1990s models)
Sinfoni
Streetwirez
Stinger
Treo
US Amps
Wrangler Alternators
Xtant
Zapco
__________________
Just remember this is an opinionated list and everyone has the right to have their own opinion about any brand (even sony)..This serves as a pretty good guidline IMO. Hope that gives you a little help.
Dave
Pioneer Premier DEH-P660
15" Kicker CVR
Profile AP1000M
It's Loud
Posted By: nc5er
Date Posted: November 02, 2004 at 6:58 PM
Paul, get yourself a small 2 channel amp, even a pre owned one and some good front speakers. You will have a grin for a whole week  when you hear the difference.
Posted By: paul167
Date Posted: November 03, 2004 at 5:45 AM
Okay seems like I'm gonna go for the 2 maybe 4 channel amp solution. My question is, is it possible to have some decent bass with only a small amp (30W RMS) and some small speakers (I can only fit 17cm in my doors) ?
