Amp Turning Off
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=42246
Printed Date: May 10, 2026 at 4:03 AM
Topic: Amp Turning Off
Posted By: Daikos
Subject: Amp Turning Off
Date Posted: November 04, 2004 at 4:43 PM
I'd like to start off by saying that i've read other threads of this sort but none exactly describe my problem so don't think I didn't look ;)
I recently (4 weeks) installed a Legacy LA1870 amp in my car to power two 12" subs. They have been working decently but since I installed them frequently the amp would turn off for a few minutes then turn on again only to turn off again later. At first I thought they weren't receiving enough power but this didn't prove true. Second I thought wires weren't connected all the way but this doesn't seem to be the problem. One thing i noticed was that at first it seemed that the amp would kick back on when I revved the engine but that has since ceased to happen.
It worked for a good week without this problem occuring but recently it started again and now the amp powers itself down when I turn my head unit up to anything past 7. It had easily been doing 20 prior to this. I am thinking that the ground connection may not be suitable but am not sure and want to see if anyone has suggestions before I try anything else.
The only alteration I made before this problem started (two days ago) was to turn the low level on the amp down to get a deeper sound, not sure if this is what caused the problem or not.
I'm real new to car audio so any help that can me given would be greatly appreciated.
Posted By: jeffchilcott
Date Posted: November 04, 2004 at 4:53 PM
well how do you have your sibs wired? how is it wired to the amp?? I dont even know if this amp is 2 ohm stable, let me know how all the speakers are wired to the amp
------------- 2009 0-1000 Trunk WR 154.0DB 2009 1001+ Trunk WR
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Posted By: Daikos
Date Posted: November 04, 2004 at 5:23 PM
First i made a mistake I'm using a Legacy 1470 not 1870. I currently have it wired like this:
Posted By: Daikos
Date Posted: November 04, 2004 at 5:24 PM
https://www.legacycaraudio.com/itempage.asp?model=LA1870 theres the model and info on it if that can help.
Heres a pic of how the subs are wired in:
Posted By: Daikos
Date Posted: November 04, 2004 at 5:25 PM
Ooops sorry for double post. ignore the first one didn't realize i had sent that through. its full of false info hehe
Posted By: audiopro111
Date Posted: November 04, 2004 at 6:53 PM
what gauge is the power.ground and speaker wire and did u ground over a painted surface does this amp have a crossover and how is it set ,is anything else powered off the same lines of your amp and are the 2 subs the only thing running off thjis amp............... p.s. Make sure u have proper ventilation on this amp and if amp has internal fan make sure it's coming on Later, ------------- AudioPro111
Date Posted: November 04, 2004 at 7:03 PM
well from that I would say possible bad ground, have you actually looked at the amp when it cuts out, try to get it to cut out while looking at the amp, this will tell if its going into protection, or shutting off...Either could be a bad ground, you could have a bad remote wire. you could have wire on one of the speakers touching the basket or each other, any of which would cause trouble look for these and let us know
2007 World Record
Posted By: Daikos
Date Posted: November 04, 2004 at 7:24 PM
Audiopro:
Power is 4 gauage as is ground wire. Speaker wire I'm not sure on its pretty thin and came unlabeled as far as I know.
No crossover and nothing else is powered except for the amp which is running the two subs.
The ground was over a partially painted surface (some paint left on it some off) so I'll try scraping a spot clean and putting it there.
And the ventilation is good as far as I can tell the amp is right on the box out in the open.
Jeffchilcott:
It goes into protection mode so I will try and change the ground and check the speaker wiring.
Thanks to both of you, this is the first system I've ever set up in a car so I'm real new to everything
Date Posted: November 04, 2004 at 7:34 PM
also change the speaker wire go to a thicker gauge a thin wire causes amp to over heat because it sees to much resistence and this can cause to go into protection also. Good Luck, ------------- AudioPro111
Posted By: Daikos
Date Posted: November 04, 2004 at 7:38 PM
Alright I'll do that.
Thanks again.
Posted By: customsuburb
Date Posted: November 04, 2004 at 9:39 PM
Make sure you are grounding to the actual vehicle chassis...not the rear deck or a seat or seat belt bolt. -------------
Posted By: bumpingjeep
Date Posted: November 04, 2004 at 10:16 PM
if none of these suggestions work...go ahead and tell us exactly what kind of subs you are using...svc or dvc and ohm load...i know you said you were running them in two channel stereo...but it sounds like the ohm load might be a little too close to what the amp is capable of handling with x amount of a voltage input signal...thats another thing... is it 4v or higher preout from rcas on deck or what...i know it seems like a stretch guys...but i have seen plenty of customers have this issue before
Posted By: Daikos
Date Posted: November 06, 2004 at 4:20 PM
Update:
the wires leading to the subs were just slightly touching, fixed this and they are working perfectly again.
