wiring speakers
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=42562
Printed Date: May 14, 2026 at 12:47 AM
Topic: wiring speakers
Posted By: bluesfan
Subject: wiring speakers
Date Posted: November 08, 2004 at 10:15 PM
 I would like to know how to tell which wire is positive and negative when wiring up car speakers ?   I have a sony head unit 4 x 40 watt , I had put in some 6.5 mtx speakers in the back of the car and they now sound like crap when any bass is heard , I was told that I more than likely hooked them up wrong , meaning the positive wire to the neg. post on the speaker and vice versa....there is no amp in this set up....do u think I need one
Posted By: stevdart
Date Posted: November 08, 2004 at 10:58 PM
Adjust fade to rear only.  Then reverse the wiring on one rear speaker only.  Listen to it, and if it sounds better than the way it was before, the two rears are now in phase.  Now check the rear phase against  the fronts (fade back to the center).  Position yourself equally between front and rear.  Are they the same volume?  In phase.  Rears can't be heard?  Switch the wiring on both rears.  It should be good to go.
If the bass is still substandard to what you expect, then you are expecting too much from the head unit and indeed should look into amplifying.
Posted By: jeffchilcott
Date Posted: November 08, 2004 at 11:02 PM
Typically the larger of the 2 post's on the speaker is your postive terminal
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
