Is this the best setut for my system?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=42653
Printed Date: May 12, 2026 at 9:43 PM
Topic: Is this the best setut for my system?
Posted By: mrdragon
Subject: Is this the best setut for my system?
Date Posted: November 10, 2004 at 6:25 AM
Hi everyone,
Can some tell me whether this is the best setup to run my system.
My H/U got 4 internals amp and i am thinking of using 2 channels to run a 4" front speaker at the same time i want to use another 2 channels to run the tweeters. And i will run 2 subs in the trunk with 1 amp....and take out the 6x9 rear speaker.
Can someone tell me whether this is the best
Posted By: boxmaker85
Date Posted: November 10, 2004 at 8:43 AM
na man Keep those 6x9 speakers.  Don't do just one 4" and tweeters.  Keep a good balance in the midrange and midbass.  But yeah do run those subs though.
Posted By: kfr01
Date Posted: November 10, 2004 at 12:05 PM
See if you can fit a slightly larger driver up front. If you can, then go for it, take the 6x9's out.
I'm not a fan of rear fill, the more power you can get on your front stage the better. Take out the 6x9s if you can get some more bass than 4" drivers up front.
New Project: 2003 Pathfinder
Posted By: Rushman
Date Posted: November 10, 2004 at 6:08 PM
While most people prefer a "Front Stage" set up , I prefer a full surround sound. I would ditch the 6 x 9s in the rear and custom fit a nice compenent set and also go with the sub woofer. Thats just me but its really up to you and what your prefrences are.
99 F-one fitty
Pioneer Premier H/U
Alpine EQ
Kicker 1200 amp
4 Kicker comp 10s
6 kicker SS65.2 components
