Wrong to use factory harness12V+/-
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=42696
Printed Date: May 12, 2026 at 9:34 AM
Topic: Wrong to use factory harness12V+/-
Posted By: brianrwebb
Subject: Wrong to use factory harness12V+/-
Date Posted: November 10, 2004 at 7:48 PM
I have always read to avoid using the factory 12V power/ground leads in the wiring harness for the install of an upgraded HU, however, this is how it is done in nearly every single install bay in the nation: find the corresponding Metra adaptor for make/model, splice, crimp or solder and slide the HU into the sleeve and the clients on his way.
doesn't this invite the greatest potential for ground loops?
who here uses the factory harness power/ground? while others use direct, fused 12V power from the battery and a chasis ground for their installs? any opinions, stories would be great to hear.
I'm speaking mainly of HU, as any multi-Amp system would require the install of high current power anyway.
...enjoy hearing all of the problems, and problem-solvers on the service.
Posted By: Asmodeus
Date Posted: November 10, 2004 at 10:26 PM
Depends on the headunit and the size of the internal amp....
The new V-Drive Head Units from Alpine I always try to make my own power and one of them comes with an 8 Ga install kit....But with most small HU I dont worry about it...
posted_image
Making the World A Louder Place
