Brahma 12'' or 15'' ?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=43212
Printed Date: May 14, 2026 at 3:33 PM
Topic: Brahma 12'' or 15'' ?
Posted By: winston_smith
Subject: Brahma 12'' or 15'' ?
Date Posted: November 17, 2004 at 4:43 PM
Ok so here's my problem, i cant figure out if i should get a 12" or a 15" brahma. i have upto 2 cu/ft to work with, i listen to a lot of rock music with some rap and other things trown in. I want it to be load but still sound good, i need to go with only 1 sub as thats what u can afford. i have a infinity amp that puts out 657W at 2 Ohm. Also i'm gunna go with a sealed box.
Posted By: jeffchilcott
Date Posted: November 17, 2004 at 4:48 PM
i would go with a 12, for rock music I find a 15 to be a little sloppy
------------- 2009 0-1000 Trunk WR 154.0DB 2009 1001+ Trunk WR
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Posted By: Steven Kephart
Date Posted: November 17, 2004 at 6:10 PM
2 cubic feet should work great sealed with the Brahma 15. The Brahma 12 requires half that space. You will get a little louder and a little lower with the Brahma 15, and I can guarantee you it won't sound sloppy. BTW, is that amp 1 ohm stable? The Brahma's have dual 2 ohm voice coils, so you can either have a 1 ohm or 4 ohm load. Steven Kephart Adire Audio -------------
Date Posted: November 17, 2004 at 6:24 PM
err not that i know of i think it's only 2 ohm stable, but i got it cheap enough i'm sure i can sell it off.
Date Posted: November 17, 2004 at 7:23 PM
Ok well i can get a good deal on a jbl powervalve amp.
600W rms at 4 Ohms
1200W rms at 2 Ohms
and it's 1 Ohm stable, it does not have a subsonic filter but since i'm going sealed i dont need it right? subsonic is for ported right?
Anyhow it's a factory renewed amp and it's only 200$
Posted By: uthinkuknoaudio
Date Posted: November 17, 2004 at 8:35 PM
JBL makes great amps, oh and go with the 15''
------------- "I don't play games. I play Nakamichi and that for real yo" - Probably some japanese kid said this in the early 80's trying to sell stereo out of his trunk lol.
