Wiring Patterns?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=43709
Printed Date: March 10, 2026 at 6:40 PM
Topic: Wiring Patterns?
Posted By: arkansasboy
Subject: Wiring Patterns?
Date Posted: November 24, 2004 at 1:19 PM
Hey what wiring pattern should i use for a Dual Voice Coil Memphis Power Reference?? I am using a 350.2 Kicker amp, i was thinking about doing it where there is a 4ohm load.... but i'm not sure whats the bestway to get it to sound good?
Dan Tha Man
Posted By: daze
Date Posted: December 02, 2004 at 9:27 PM
what load are each coil ? (should be rated in ohms) and if its 2 channel that I am sure that it is only 4 ohm stable if its bridged and 2 ohm stereo... but you should post the specs from each.
