lights dim
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=43817
Printed Date: March 11, 2026 at 6:09 AM
Topic: lights dim
Posted By: FRANCO90
Subject: lights dim
Date Posted: November 26, 2004 at 12:07 PM
when the bass hits in my car the head lights dim what can I do to fit this problem
Posted By: supradude
Date Posted: November 26, 2004 at 1:01 PM
This usually means that you need a high output alternator. How many watts is the amp on your subs? Sometimes you can get by with a cap in line with the sub amp. ------------- '85 Toy
Posted By: winston_smith
Date Posted: November 26, 2004 at 6:19 PM
You might wanna try the big 3 also, much cheaper then a new alt and it will help to some extent. Might stop the dimming or it could just help a little.
https://forum.sounddomain.com/ubb/ultimatebb.php?ubb=get_topic;f=5;t=007801
Posted By: FRANCO90
Date Posted: November 26, 2004 at 7:30 PM
what about if I use a 1 Farag CAP also what is the proper way to wire it to the amp
Posted By: furflier
Date Posted: November 26, 2004 at 7:49 PM
If you list what kind of amp or amps & what kind of subs, with the power ratings,we can give you more help.
Posted By: uthinkuknoaudio
Date Posted: November 26, 2004 at 8:05 PM
Perhaps try a batcap, install it by your amps and it acts like a 50+ Farad Capacitor. They are cheap on ebay for like $75. Might be worth a look. Overall the high output alt would be the most efficient way of settling the problem - quite pricy but its worth it.
------------- "I don't play games. I play Nakamichi and that for real yo" - Probably some japanese kid said this in the early 80's trying to sell stereo out of his trunk lol.
Posted By: FRANCO90
Date Posted: November 26, 2004 at 8:15 PM
OK THIS IS WHAT I HAVE IN MY CAR ALPINE CDM-7854 JCC AMP KS-AX4750 SHAUN PALMER SIGNATURE SERIES Bridgeable 2-Channel Power Amplifier Continuous Power (RMS) of 100W per channel into 4 ohms 20Hz-20kHz at no more than 0.08 THD Max. Power 560W Mono 2 Ohm Stable Operation (2-8 Ohm Allowable) Bass Boost Control Custom build box for Rockford Fosgate Punch Audiophile 10" woofer VIDEO BOSS DVD300V 7’ in flip down LCD 5’ mmobile TV Prestige car ALARM
Posted By: FRANCO90
Date Posted: November 26, 2004 at 8:17 PM
Do i dare ask what the heck does that say??? I'm still recovering from the dizziness of all those characters...
Posted By: FRANCO90
Date Posted: November 26, 2004 at 8:18 PM
Posted By: FRANCO90
Date Posted: November 26, 2004 at 8:20 PM
OK HERE IS WHAT I HAVE IN MY 97 TOYOTA RAV4 ALPINE CDM-7854 JCC AMP KS-AX4750 SHAUN PALMER SIGNATURE SERIES Bridgeable 2-Channel Power Amplifier Continuous Power (RMS) of 100W per channel into 4 ohms 20Hz-20kHz at no more than 0.08 THD Max. Power 560W Mono 2 Ohm Stable Operation (2-8 Ohm Allowable) Bass Boost Control Custom build box for Rockford Fosgate Punch Audiophile 10" woofer VIDEO BOSS DVD300V 7’ in flip down LCD 5’ mmobile TV Prestige car ALARM
Date Posted: November 26, 2004 at 8:27 PM
And all of that means what? We told you what you need. A capacitor, batcap, or a high output alternator. Make sure you upgrade your cables from 12 guage to like 8 or 4 underneath the hood to have a strong electrical connection. No one said this would be cheap, but it will save you from shorting out everything and making your budget a lot more.
Posted By: furflier
Date Posted: November 26, 2004 at 8:29 PM
The amount of power you are running should not be that much of a strain on your electrical system. Check your battery cable connections make sure they are clean & tight. You might need to also have your alt tested. -------------
Posted By: FRANCO90
Date Posted: November 26, 2004 at 8:34 PM
ok I have 1 Lightning Audio Strike LSD10-03 now so I connect hot wire to cap and then from Cap to amp ? see this is when I get lost
Date Posted: November 27, 2004 at 8:32 AM
Correct. Then just ground the cap to metal near it.
