Components Ohms?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=44643
Printed Date: May 13, 2026 at 10:07 PM
Topic: Components Ohms?
Posted By: eeh1025
Subject: Components Ohms?
Date Posted: December 07, 2004 at 12:46 PM
Hey Guy are all compnets 4 ohms, is there any way to change them to 2ohms?
Posted By: Asmodeus
Date Posted: December 07, 2004 at 12:53 PM
Most are 4 ohm.....The only way you can get 2 ohm would be to wire 2 sets in parallel....Why do you want 2 ohm just so I know.... ------------- Making the World A Louder Place
Posted By: kfr01
Date Posted: December 07, 2004 at 12:57 PM
1) Most are 4-ohms.
2) There's no way to change it to 2-ohms that does what you want it to - increase the power to the speaker.
3) Even if you could, there's no real reason to do this anyway. Even if you "only" have 50w going to a pair of components they will get plenty loud. Assuming the jump to 2-ohms would actually double the power, which is doubtful, you'd only be at 100w. Doubling amplifier power gives a 3db increase in SPL. 3db is audible, but is a rather small increase in volume.
If you are clipping your amp or find you simple need more power, again doubtful, then buy a new amplifier.
------------- New Project: 2003 Pathfinder
Posted By: kklagge
Date Posted: December 07, 2004 at 1:01 PM
Image Dynamics makes a 2ohm set (the chameleons come in either 2 or 4 ohm)
Posted By: eeh1025
Date Posted: December 07, 2004 at 1:40 PM
One more question, I have a set of Infinty kappa 6x9 3ways and a 3 1/2 set of speakers, how much should i run to each and what is the min i can run to each of them.
Posted By: kfr01
Date Posted: December 07, 2004 at 1:44 PM
Lets turn that question around. What kind of amplifier do you currently have?
Posted By: /R7
Date Posted: December 07, 2004 at 3:08 PM
your asking a questions we cant answer
if you gave us model #'s and or even the specs to the speakers that would make it much easier to tell you, how much is too much.
and the minimum you can run them with is 1watt
BE MORE SPECIFIC.
Posted By: eeh1025
Date Posted: December 07, 2004 at 6:56 PM
Sorry guys
these are the speakers im running right now
I have a Fosgate punch amp its the 150s model, its a 2 channel amp, I was got to chose a 4 ch but i like to control front to back im not worried about side to side. do you think this amp is plenty good enough for these speakers?
https://www.crutchfield.com/S-X3F6lwclLrK/cgi-bin/ProdView.asp?g=51100&I=108325CF
https://www.crutchfield.com/S-X3F6lwclLrK/cgi-bin/ProdView.asp?g=52300&I=1086935I
Posted By: stevdart
Date Posted: December 07, 2004 at 7:30 PM
That amp must be discontinued, there is no reference to it at the Rockford site. I don't know it's power output. You have 3.5's at 35 watts, and 6.9's at 110 watts. Both have what look to be good crossovers (but how in the world do they make them so small?). The power needs to go to the larger ones, of course, but they're probably in the rear deck, right? You need to maintain stereo separation, so connecting left to right is out. That would mean connecting front and rears, but the Rms is vastly different. So... Considering everything, I would run those speakers at no lower than 4 ohms. Which means don't parallel any of those speakers together. That means either get another 2 channel amp, or trade for a 4 channel. And the most volume, most power, should go to the front of the vehicle for proper staging (presence of the music). But an alternative is to run the 3.5's off the head unit power, but install them in the rear. And move the bigger ones up front and run them normally off your amp.
Posted By: eeh1025
Date Posted: December 07, 2004 at 8:33 PM
So what you are saying is use the amp for the 6x9s and run the 3.5s on the head unit correct, Also i have a mrv-f250 just laying around should i use that?
thanks
Posted By: stevdart
Date Posted: December 07, 2004 at 9:23 PM
Correct. No. Don't use it. Send it to me. lol Sure, use it, why not? If the power is too great for the 3.5's, you can adjust the gain a little, or just keep the amp gain at minimum if you have to. There should be a very minor difference in power requirements by running another amp at a 4 ohm load to a small component set.
