2005 chevrolet silverado stereo wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=44740
Printed Date: May 12, 2026 at 6:18 PM
Topic: 2005 chevrolet silverado stereo wiring
Posted By: atpsales
Subject: 2005 chevrolet silverado stereo wiring
Date Posted: December 08, 2004 at 5:26 PM
need a wiring diagram for a 2005 chevrolet silverado. the system has a bose system. Want to add subwoofers and amp.
------------- rjturner
Posted By: dustin_parks79
Date Posted: December 09, 2004 at 2:40 AM
if your going to leave the bose system and just adding subs and amp the best way to go is run your amp wire off the bat.....like normal....and ground like normal.......but get into the rear speekers......and install a high level to RCA line converter for your RCA plugs, and well of course run your remote w/ your ignition wire.....
Date Posted: December 09, 2004 at 2:42 AM
also if you dont want to take off the panels to get to the speekers in the back to hook up the converter than you can hook it up from behind the stero you back speeker wires are ........drivers side.....brown and yellow.......passangers side blue and light blue.
