unwanted noise
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=46217
Printed Date: May 12, 2026 at 10:09 AM
Topic: unwanted noise
Posted By: ThomasWilson
Subject: unwanted noise
Date Posted: December 28, 2004 at 2:28 PM
i just installed an eclipse cd player in each of my two siblings cars.  one is a '92 Lexus ES300 and the other is a '99 Nissan Maxima.  in both cars i can hear the cd spinning noise through the speakers.  also i can hear when the laser is moving tracks.  one car is sort of slight but the other is really noticeable.  i would really like some suggestions on how to fix this problem.  thanks alot.
Posted By: ~AFAccord~
Date Posted: December 29, 2004 at 2:37 AM
Did you install the same model units in each car?
Black Cherry
"Experience is something you never get until just after you need it."
Posted By: haemphyst
Date Posted: December 29, 2004 at 8:12 AM
Turn the gains down on the amplifiers! If you have them cranked up, it is possible to hear this noise. Also, make certain your ground for the head unit is as good as you can get...
Posted By: uthinkuknoaudio
Date Posted: December 29, 2004 at 8:15 AM
You might have a bad set of RCA's or a bad ground. I'd check them both. I had a similar problem with an Eclipse HU i had hooked up in a friends car and i fixed it with a new ground.
"I don't play games. I play Nakamichi and that for real yo" - Probably some japanese kid said this in the early 80's trying to sell stereo out of his trunk lol.
Date Posted: December 30, 2004 at 4:27 PM
yeah, i installed the same model in both cars, it's an eclipse CD3414.  i used a new ground for the lexus and that helped a bit but not enough. i think next i'm going to try to ground the cage to the engine block (i also have some alternator winding noise) to see if that helps also.
Posted By: bigboi11
Date Posted: January 03, 2005 at 8:01 AM
Posted By: bigboi11
Date Posted: January 03, 2005 at 8:03 AM
Get some PAC ground loop isolators it will not take away from the sound at all and all of the noise will go away.
