Big Problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=46318
Printed Date: May 11, 2026 at 4:40 AM
Topic: Big Problem
Posted By: fastinanaurora
Subject: Big Problem
Date Posted: December 29, 2004 at 7:05 PM
I Drilled a kicker solo baric into a sqaure hole...
put some power to the sub and as it increased the sub started to jump out the box....
Granted I did use 2 different types of screws because I didn't have many...but
My question is did I f**k up the box with the holes already ... Tweeter etc. told me that
the holes could be used as a pilot hole for a bigger screw...tomorrow I'll pay them to fix it...
Any advice....did I really f**k up or could it be fixed..
What makes my car Bang:
Kicker KX 600.1 Mono amp (2004)
Kicker Solobaric L7 10 (2004)
Long Ported Box Single
Kicker 200.4 4 Channel(2004)
Kicker DX 60 6 1/2
Rockford Fosgate FRC3369 6x9
Posted By: forbidden
Date Posted: December 29, 2004 at 7:12 PM
Use a thicker screw, use all the holes and if the screws are ripping out of the box, then make the front baffle board thicker. By the sounds of it you have the sub mounted to 1/2" mdf and no doubt they will rip out when enough power is applied.
Posted By: hotwaterwizard
Date Posted: December 29, 2004 at 11:48 PM
I use Nutplates and Machine screws.
the nutplates Dig into the wood as you tighten the screws.
You can get them at Lowes, Home Depot, or any Cabinet Shop.
posted_image
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
Date Posted: December 31, 2004 at 7:59 AM
Problem fixed thanx Now I have this problem...
Kicker DX 60 6 1/2
