quick double check
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=46407
Printed Date: May 10, 2026 at 6:17 AM
Topic: quick double check
Posted By: cavyracer2003
Subject: quick double check
Date Posted: December 30, 2004 at 5:13 PM
just double checking to make sure this wiring is ok....its a dvc 4 ohm sub with a mono amp an i will be running it at  2 ohms.....on the sub i connect the pos. and pos. and neg. to neg. then from one of the pos. leads i go to the pos. on the  amp and from one of the neg leads i go to the neg. on the amp.....on my amp it says
Speaker 1: +    -  Speaker 2: + -
 i just use speaker one for my pos. and neg. hookups on the amp right?and it doesnt matter which lead i run my sub to my amp from right?? thanks for the help
Posted By: stevdart
Date Posted: December 30, 2004 at 5:55 PM
Right on all counts.
Posted By: bigboi11
Date Posted: December 30, 2004 at 6:07 PM
Sounds good to me
Date Posted: December 30, 2004 at 7:09 PM
ok guys....ill let u know how it sounds
