Return of the Steel Box
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=46453
Printed Date: May 09, 2026 at 7:07 PM
Topic: Return of the Steel Box
Posted By: chevyman26
Subject: Return of the Steel Box
Date Posted: December 31, 2004 at 12:58 AM
posted_image
Well I went ahead and did it. This box is made of 3/8" steel, welded tight. I loaded in my IDQ10 because it's what I'm used to lisening to, and by ear is the only kind of testing I can do. During play it's actually quite solid. It was very boomy but clean sounding, as if somebody in the next car over had a couple of  W7's going. I attribute this to the excess airspace that it has for now (see below). Anybody familiar with Image Dynamics can see that this is way too much air space for a 10". The box is roughly 12"x12"x12". So needless to say, I kept the levels down. I plan to spray in some rubberized undercoating, then add in a layer of either 1/2" or 1" SoundRite (a low density soundproof sheeting) and spray it up tight again with the undercoating.
You'd better get me out of this lord... or else you'll have me to deal with. -- Hunter S. Thompson "F.A.L.I.L.V."
Date Posted: December 31, 2004 at 1:06 AM
O.k, let's see if it works this time. If you can or can't see the picture let me know - this is my first time trying to post a pic., doesn't seem to be working.
Also forgot to finish last post.  Any ideas/questions would be appreciated.  Thanks!
Edit:  Oh Yeah! The box also wheighs 87.5 lbs. without the driver! Add a 20 lb. sub and try to gently ease it into the back seat of and ext. cab chev. hehehe.
Posted By: phuzun
Date Posted: December 31, 2004 at 3:52 AM
cant see the pic.  Sounds heavy though.  With all the damping it should be pretty nice though.  Should try shooting it with a gun see how tight it is.
Posted By: stevdart
Date Posted: December 31, 2004 at 10:23 AM
Image upload:  posted_image  First be sure that the file image size is under 30 kb and has an extension .jpg (small letters).
Posted By: auex
Date Posted: December 31, 2004 at 11:55 AM
Yup, you can't link to an image on your harddrive.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: Poormanq45
Date Posted: December 31, 2004 at 2:39 PM
I'm curious, why did you use 3/8in steel? Why didn't you go with aluminum, or were you not concerned about weight?
Also, get some sound deadning material in there right away or else that thing is going to resonate like a beoch
Date Posted: January 04, 2005 at 1:25 AM
posted_image
O.K., I'll try it again. Let me know if you can see it!
I used the 3/8" steel because it is what was available to me, and I just wanted to know how a steel box would sound. I had posted a question about it a while ago before I built it. It seemed like nobody really had ever seen or heard one, so now here one is. I would like to try aluminum for the weight factor, as well as the fact that it is a softer, and therfore more sonically dead material. But I have access to "scraps" at work for free, and we really only use steel or stainless steel there, so that's the story on that.
This isn't going to be used regularly, as it is way too heavy. I'm only kind of testing the idea of using steel for an enclosure.  Maybe I'll just hook it up to the garage stereo when the vehicle testing is over. Hmmm....
Posted By: Urban_S
Date Posted: January 04, 2005 at 1:30 AM
I can't see it.
Date Posted: January 04, 2005 at 1:32 AM
What kind of gun are you talking about? Like firearm bang-bang gun? Do you realize how solid 3/8" steel is? I wouldn't dare shoot my .280 Remington at it, from dead on anyways.
Posted By: phuzun
Date Posted: January 04, 2005 at 2:41 AM
yeah, thats what i'm talking about, should be pretty solid.
