good inexpensive system?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=46757
Printed Date: April 19, 2026 at 11:11 PM
Topic: good inexpensive system?
Posted By: Xplorer
Subject: good inexpensive system?
Date Posted: January 03, 2005 at 11:11 AM
I know its almost an oxymoron but i have a friend with a civic that wants SOMETHING(amp and sub w/box) in there trunk for less then $200. I warned them about alot of stuff and that they would most likely be replacing it soon down the line but none the less they want something thats inexpensive and works. Ive seen alot of promo packages and was curious if anyone new what amp/sub combo is the best for around $200 or less.
Basically whatever is the best for less...i saw these ...
https://www.cardomain.com/item/MTXRTP212R
https://www.cardomain.com/item/MTXRT10X2TA
https://www.crutchfield.com/S-56xc6anNbhR/cgi-bin/ProdView.asp?g=208150&I=049DWE304S
https://www.cardomain.com/item/POWOV2520
https://www.cardomain.com/item/BOSRT850
https://www.cardomain.com/item/JENPS1220M
https://www.crutchfield.com/S-56xc6anNbhR/cgi-bin/ProdView.asp?g=130&I=489400MSX
https://www.crutchfield.com/S-56xc6anNbhR/cgi-bin/ProdView.asp?g=130&I=489CA400M
...open to other suggestions as well
Thanx
Peace
Posted By: pimpincavy
Date Posted: January 03, 2005 at 11:42 AM
None of that stuff is to great. I found some good deals that should be around the $200 mark.
https://ikesound.com/product-product_id/2426
https://ikesound.com/product-product_id/1010
https://ikesound.com/product-product_id/2110
https://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?Productid=14430
That amp and any one of those subs should work. But remember your friend will still need wiring and material to make a box, or money to buy a prefab one. My other suggestion would be to look around on the "Buy and Sell" section of this forum, and the one over on sounddomain. You might be able to find some good deals there.
