94 camry, 3 amps to 4 subs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=47911
Printed Date: March 14, 2026 at 4:22 AM
Topic: 94 camry, 3 amps to 4 subs
Posted By: Stripes26051
Subject: 94 camry, 3 amps to 4 subs
Date Posted: January 17, 2005 at 2:50 AM
I am installing 3 amps to 4 subs in my friends car (94  camry) could sombody give me an idea on how to wire and get the most wattage out of it. i was told to daisy chain it       P\+[ A ]-\___/+[ A ]-\___/+[ A ]-/G  and then take the main amp and do the same for the speaker to the two subs and then bridge each other amp to their own sub
-jordan
Posted By: petergozinya
Date Posted: January 17, 2005 at 3:20 AM
more info (model amp's) (speakers) SOOOO! IS YOUR CAR ON FIRE YET! Be carefull sound's like you're about to pull alot of power !
   thad
Date Posted: January 17, 2005 at 3:28 AM
-jordan
Glad to see you 're here many people would be more than glad to help you!=) I THINK YOU'RE CRAZY!  pulling three amp's off a camery altenator?
Posted By: jeffchilcott
Date Posted: January 17, 2005 at 6:43 AM
really need model #'s of amps and models of subs, not all amps are able to daisy chain
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Date Posted: January 17, 2005 at 11:11 AM
Its not that great it crappy power acoustic amps but there rockford subs basicly just temps cuz hes know sum1 who will buy them from him for double what he payed but i kno the amp can be daisy chained
Posted By: kfr01
Date Posted: January 17, 2005 at 11:19 AM
What was your question?
New Project: 2003 Pathfinder
Posted By: twofootthumpin
Date Posted: January 17, 2005 at 11:34 AM
    First off with any three amps unless they are rated for less than 100 watts a piece I would not trust that stock alt. smoke that and your all done. But because I have this feeling they are larger amps theres no way you can keep anything powered. And with three amps and four subs your set up is strage as all get up, it would help to know what you want to run and what is in what boxes, specially if model numbers were used. But mainly I would not trust the stock alt. for anything that you are willing to run HO is the way to go. Most amps I would not trust doing the daisy chain with just for compatibility problems and fire hazards sometimes its just better to run two subs on one amp and and a sub on a amp for the others. But I guess it depends on your set up and what you have for compatibility.
Yes, money is everything when it comes to a huge system.
Date Posted: January 17, 2005 at 5:03 PM
its three boxes basicly two singles and one dual they are all 12's, right now its only two amps and the four subs its pulling some power but not much i have a voltometer hooked up and im not loosing much, i need more power so i am ordering another power acoustic amp that rated at like 980wats so i figure its putting out like 300 or so and  i was planning on getting a fused distribution block and wiring it all out from there.i figured that would be easiest but im not sure how much would a new alternator cost
Posted By: stevdart
Date Posted: January 17, 2005 at 5:28 PM
............lol............I'm scratching my head like kfr01 is........as he said, is there a question in there somewhere?
Date Posted: January 17, 2005 at 10:11 PM
Please comb that for us.as you can gather we are wired for sound ! "two single's one dual" 'two amp's " FOUR SUB'S!-YOU NEED TO HELP US BEFORE WE CAN HELP YOU! (do you want to run notch filter's on you're rear 12's and run one of them sub bass.) where did that fourth sub come from?
flare gun.
Date Posted: January 18, 2005 at 3:00 PM
i kinda figured it out i answered my own questiona im ran 2guage from battery to trunk and then i broke it down to 4 guage into each amp and i used the smaller amps to power the two outside subs(one to one) and then i bridged the bigger amp and conected it to the two other subs i will upload pics when i get them so you understand
