custom sub box
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=47914
Printed Date: March 14, 2026 at 2:48 AM
Topic: custom sub box
Posted By: jimmyrose
Subject: custom sub box
Date Posted: January 17, 2005 at 4:10 AM
hi, the sub im thinking of getting has needs a 1.5cu feet sealed enclosure or 2 cu feet ported. to make a rectangular box this big to fit where i want it will be just about impossible cause i have the targa roof that clips into the boot which give me about 10" on an angle between the backseat and where the targa will sit. the sub is just over 8" deep so im going to have bugger all room between the ass end of the sub and the bottom of the enclosure. the enclosure will also have to be fairly long to allow for how thin its going to be. how will this effect the sound is it okay to have a mong enclosure or will it stuff sh*t up?
thanks
Posted By: jeffchilcott
Date Posted: January 17, 2005 at 6:41 AM
as long as the proper amount of airspace is there then you will be fine, if you are going sealed you can go a little bit smaller and use fill to fool the sub into thinking it is in a bigger enclosure
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Posted By: jettagli03
Date Posted: January 21, 2005 at 8:23 PM
its not good to have LIKE no airspace behind the woofer is what i have ONLY heard. i asked around because i used to be into custom box making and made some tight fit boxes and where ever i went on the net and asked around they said the reccomended around 2-3 inches behind the magnet
