Help Maintaning power in 01 civic
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=48015
Printed Date: April 10, 2026 at 12:43 PM
Topic: Help Maintaning power in 01 civic
Posted By: Stripes26051
Subject: Help Maintaning power in 01 civic
Date Posted: January 18, 2005 at 3:22 PM
My girlfriend has an 01 honda civic she has one power acoustic amp (LT980/2) Powering two 12inch Power acoustic Subs(fubr12) i ran it with 4 gauge from the battery according to her voltometer (which is built into her radar detector ) her volt are jumping alot when the bass hits, im talking like 14.1 to 11.9 and sumtimes even worse. i have a cap but i didnt install it yet ive been to lazy but do you think that will do it
Posted By: bullman96
Date Posted: January 18, 2005 at 6:04 PM
doubtful. check your wiring job. tell her to learn to live with it unless you want to install a high output alternator. the cap might work at least by evening out the voltage a bit.
Posted By: auex
Date Posted: January 18, 2005 at 6:11 PM
Your meter is not accurate, at all, not in the least. You can't get an accurate voltage reading from the cig lighter plug. If you are really worried about it test the voltage at the battery.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: January 18, 2005 at 6:55 PM
thanks ill wire up a reg voltometer
Posted By: forbidden
Date Posted: January 18, 2005 at 8:31 PM
Ensure that her ground wires are all upgraded as well. Electricity is an algebra equation, what you do to one side you must do to the other.
------------- Top Secret, I can tell you but then my wife will kill me.
