Need help wiring Chevy Prizm 12v switched
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=48406
Printed Date: May 15, 2026 at 10:42 PM
Topic: Need help wiring Chevy Prizm 12v switched
Posted By: quick4321
Subject: Need help wiring Chevy Prizm 12v switched
Date Posted: January 23, 2005 at 6:12 PM
I tested all the wires in the wiring harness for the radio and only one shows 12v and it shows it reguardless of key position (off/on). Where is the switched 12v? Since the only wire I found that shows 12v never turns off my radio dosent turn off when I stop the car. Does a Checy prizm have a switched 12v I can tap into? Thanks for the help!
------------- Clarion DRX9255
Dynaudio MD130, MD140/2, MD160, MD170
(4) ID V3. 12" Dual 2ohm IB setup
EPX2 Symmetry w/ zapco line drivers
Monior 1 amps (2)MK2.120, MK4.70
Hifonics Colosus VII 1600x1
Posted By: stang351w
Date Posted: January 23, 2005 at 6:21 PM
hey there, on all the newer chev's that i've done like that i've gone straigh to the ignition harness to find the switch'd wire there, on that vehicle i beleive it's still the basic chev colors and your switch'd wire should be orange for the acc. however, please double check that with a multimeter befor you wire it in. but thats where i've ran my acc wires for the newer chevs. you might be able to find another spot around the fuse box. but that's all i know for now :)
Date Posted: January 23, 2005 at 6:24 PM
Ya I have a 1998 Chevy prizm and I cant find the 12v in the radio harness. I guess I, going to go looking in the ignition harness. Time to break out the multimeter. Its jsut so clod here, I was looking for the easy way out. LOL. Thanks
Posted By: geepherder
Date Posted: January 23, 2005 at 9:10 PM
Check your fuses first. Then check the gray wire for accessory. ------------- My ex once told me I have a perfect face for radio.
Posted By: yamahaking2000
Date Posted: January 23, 2005 at 9:17 PM
if only the other car dealers made their wiring as simple as mopar (dodge/chrysler for the beginners) does.....i cant help u much but if u got something on mopar i can help u with everywire!
Date Posted: January 25, 2005 at 10:05 AM
Ya I was going to look at fuses next. I jsut figured it couldnt be blown becasue The radio was working when i removed it, but weirder things have happened. The alpine HU drained my battery even when it was turned off. The fan still runs when its off with the 9835 model :(
