Amp for SWR-1241D
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=48854
Printed Date: May 13, 2026 at 5:57 AM
Topic: Amp for SWR-1241D
Posted By: mrflip69
Subject: Amp for SWR-1241D
Date Posted: January 29, 2005 at 3:30 AM
Hey guys, would the Pioneer GM-5000T (Bridged) be enough to power 1 Alpine SWR-1241D? Also, would a cap be necessary? I've only got about 80 watts RMS running 4 channels right now from a RF amp.
Posted By: Alpine Guy
Date Posted: January 29, 2005 at 7:53 AM
How much power does the pioneer put out at 2 ohm? in RMS.
------------- 2003 Chevy Avalanche,Eclipse CD7000,Morel Elate 5,Adire Extremis,Alpine PDX-4.150, 15" TC-3000, 2 Alpine PDX-1.1000, 470Amp HO Alt.
Posted By: mrflip69
Date Posted: January 29, 2005 at 3:14 PM
Ah, I was afraid you would say that. So I need a 2ohm stable amp then huh? If I had another sub to wire, I could have done a 4ohm load right? Oh well. Does Bestbuy carry an amp that would be suitable for the sub? (Want to spend some giftcards...) Thanks
Date Posted: January 29, 2005 at 4:48 PM
To power that sub, you will need a 2 ohm stable amp, ,or one that puts out at 8 ohm, but thats unrealistic. I have no idea what bestbuy carries , but look for something in the 400-500rms range at 2 ohm.
Posted By: mrflip69
Date Posted: January 30, 2005 at 12:23 AM
Date Posted: January 30, 2005 at 10:32 AM
i don't know how it will sound...but good luck secureing it so it dosn't role around on you.
Date Posted: January 30, 2005 at 10:39 AM
If you haven;'t bought the sub yet, you can get a SWR-1221D and it will work just fine with your amp. Just wire it in series to 4 ohm then bridge it on your amp. And as for your cap question earlier, not it wont help you out. ------------- 2003 Chevy Avalanche,Eclipse CD7000,Morel Elate 5,Adire Extremis,Alpine PDX-4.150, 15" TC-3000, 2 Alpine PDX-1.1000, 470Amp HO Alt.
Posted By: stevdart
Date Posted: January 30, 2005 at 11:01 AM
Hey, there's a guy with a 94 white 'Stang who can bondo that thing in for you. Guaranteed not to go anywhere!
Posted By: mrflip69
Date Posted: January 30, 2005 at 3:01 PM
So I could use the Pioneer Amp https://www.bestbuy.com/site/olspage.jsp?id=1067391222386&skuId=6195903&type=product
And wire the SWR-1241D into a 4ohm bridged load like so? I'm only going to get one sub... I appreciate all the help :)
Date Posted: January 30, 2005 at 4:32 PM
Uhh, no i do not reccomend that. Get a SWR-1221D <<note that model # its the dual 2 ohm model. You would wire the sub in series to get a total 4 ohm load, then run the 2 wires from the sub to the bridging terminals on the amp. When you walk into bestbuy get the SWR-1221D and that amp, and your good to go. If you walk out with the SWR-1241D you will be returning it after 5 min of use beacuse you will only be putting like 100 watts to it. ------------- 2003 Chevy Avalanche,Eclipse CD7000,Morel Elate 5,Adire Extremis,Alpine PDX-4.150, 15" TC-3000, 2 Alpine PDX-1.1000, 470Amp HO Alt.
