Hookin Amp To A GMC Truck
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=48886
Printed Date: May 13, 2026 at 3:36 PM
Topic: Hookin Amp To A GMC Truck
Posted By: OneLove05
Subject: Hookin Amp To A GMC Truck
Date Posted: January 29, 2005 at 4:14 PM
Im tryin to hook up my amp up to my 2004 GMC Sierra truck, but the stock stereo has no ouputs to connect to the amp, so I bought a Adjustable Line Output Converter, but dont know which wires to hook it up to. The truck came with the upgraded Bose speakers and I know it has in amp for them, but theres so many wires I dont know which ones to hook up, If anyone call help I would really appreciate it, ive been tryin to do this for awhile. Thanks
Posted By: audeogod
Date Posted: January 29, 2005 at 8:16 PM
The line output converter may be two channel or four channel.  You can tell by looking to see how many RCA's it has on it.  One for each channel.  I don't know what brand you bought, but Schosche used to make one that Wal-Mart sold and all of it's speaker input wires were labeled.  You have to connect them to speaker output wires either off of the factory stereo, or close to the speakers themselves(these are usually the easiest access points to these wires).  If the amp is only a 2-channel amp, then you only need to use two sets(4 wires in all) of the speaker input wires.  If it's 4-channel, then you have to use all four sets(8 wires in all).  You should be able to find a factory wiring color code on this site for your vehicle, but I do not know about the Bose system specifically.  Also that line converter may have adjustable gain settings.  They may be recessed in the top of the line out converter itself.  You can adjust these with a screwdriver, usually phillips #2 size.  You do this if the output to the amp ends up being too loud even at a low volume.
That's all I can say without seeing the unit and your vehicle in person, which I doubt is possible.  Sorry.
audeogod
92 Chevrolet Cheyenne 1/2 ton truck
Pioneer DEH-41
Eclipse 2-way coaxial 4x6's in dash
Eclipse 3-way coaxial 6 1/2's in doors(cut to fit)
Pioneer GM-X332 amp bridged to Kicker 8" sub
Posted By: wheelerdr
Date Posted: January 31, 2005 at 8:19 AM
better to just buy a new deck
