sub help
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=48979
Printed Date: April 03, 2026 at 12:38 AM
Topic: sub help
Posted By: leedub
Subject: sub help
Date Posted: January 30, 2005 at 9:34 PM
I've got 3 JL WO's in a box. I believe they are 125 watt. I need a new amp. What type of amp is recomended for this type of install. I'm looking for something in the $400-$600 price range, maybe more,not sure. And how do i wire them
Posted By: wheelerdr
Date Posted: January 30, 2005 at 11:39 PM
what are the ohms on these subs but for only 375. watts you could get a kenwood excelon 811d this will give you 500 watts at 4 ohms, 900 at 2 ohms and 1000 at 1 ohm this will gove you upgrade options and is a class d amp works great and has lots of power
Posted By: leedub
Date Posted: January 30, 2005 at 11:47 PM
the subs can be used for 4 or 8 ohm installs
Date Posted: January 31, 2005 at 7:57 AM
then i would go with this kenwood amp you can run 500 watts now at your 4 ohms and then if you want later upgrade your subs to get a 1 ohm load and go for the 1000 watts
