high input and low input
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=49380
Printed Date: March 30, 2026 at 9:20 PM
Topic: high input and low input
Posted By: woeful
Subject: high input and low input
Date Posted: February 05, 2005 at 12:11 AM
What's the different when making amp connection with head unit? there's an option that you can connect as high input or low input, beside wire differently, what else is different?
Posted By: stevdart
Date Posted: February 05, 2005 at 12:24 AM
High level (speaker level) input is not as stable, does not have as good frequency response and is prone to miss some of the lowest freqs.  Use the line level if the deck has RCA preouts, and use high level only as a last resort (usually with factory decks).  In fact, if using a factory deck, buy a separate high quality line out converter and leave the amp's high level converter alone.
https://www.bcae1.com/loc.htm for more info.
Posted By: slammedb5
Date Posted: February 05, 2005 at 4:37 AM
Agreed. Leave high input alone.
EK Civic
security
no audio
