Orion 2500D
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=49468
Printed Date: March 28, 2026 at 10:05 PM
Topic: Orion 2500D
Posted By: supradude
Subject: Orion 2500D
Date Posted: February 06, 2005 at 6:44 AM
Has anybody had any experience with this amp? I was just wondering how it performs. I ran across some at a GREAT price, but I don't know much about this particular Orion model as far as rms power.
------------- '85 Toy
Posted By: aerodude31484
Date Posted: February 06, 2005 at 8:51 AM
Hey, Oron amps are one of the best that I have found on the market. I run a 4002 in my mustang with a kicker solo baric L2. With that combination it rattles the brain. The 2500D is a 2500 watt max power amp and is 1 ohm stable if needed. If you found a good deal on it grab it. The orion series are some of the best amps I have worked with. Below is a link to a pgae with the retail price and a few reviews. -Austin https://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?Productid=13472
Date Posted: February 06, 2005 at 3:14 PM
I was under the impression that this is a 2500 watt RMS amp, not max power. At least that is the way that it is advertised.
Posted By: jeffchilcott
Date Posted: February 06, 2005 at 6:36 PM
Im not sure if that is a rms or peak rating, but watched a guy run (4) 10inch w7's off one. hit well 153db. so they have more then enough power
------------- 2009 0-1000 Trunk WR 154.0DB 2009 1001+ Trunk WR
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Posted By: Alpine Guy
Date Posted: February 07, 2005 at 10:07 AM
I have a friend that bought one the other day, but is trying to figure out how to hook it up. He's out of town so i can't look at it, but he tells me it has 2 outputs?? Anyone know if this is true? he has 4 single 4ohm vc subs so he looking for a 1 ohm input. If its internally bridged or something then im guessing he just hooks 2 subs up to each output.
------------- 2003 Chevy Avalanche,Eclipse CD7000,Morel Elate 5,Adire Extremis,Alpine PDX-4.150, 15" TC-3000, 2 Alpine PDX-1.1000, 470Amp HO Alt.
Posted By: 04MDX4SQ
Date Posted: February 07, 2005 at 11:07 AM
If it is anything like the xtr pro 2400, that is RMS. These are power hungry amps, make sure you feed them well. They are a mono amp, so they are internally bridged.
------------- 04 MDX - Clarion DRZ9255 / MB Quart QAA4250 / MB Quart QSD216 / Orion Concept 97.2 / JL Audio 10w6v2
91 GMC Syclone - Delco tape deck
90 Syclone powered 2wd S10 (for sale) - Pyle CD / Fosgate 4x6
Posted By: jstruckman
Date Posted: February 07, 2005 at 11:19 AM
The amp is a mono amp even though it looks like it has two outputs. Orion has been doing that for years. They do that so if you are using more than one sub you can use both sets of connectors, but it is only a mono output.
Jazzy
Posted By: evanc
Date Posted: February 07, 2005 at 3:43 PM
Just as jstruckman said, but with a little more information.... The amp is connecting those two speaker outputs in parralel inside the amp. If you hook a 4 ohm sub up to each output, the amp will see a mono 2 ohm load. You can use one output or both, it will not make any difference. There are many companies out there that so that you do not have to cram 2 sets of wires in one output...as well as other reasons. Hope this helps... Evan
