Home amp with Car Sub
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=49749
Printed Date: May 10, 2026 at 8:09 AM
Topic: Home amp with Car Sub
Posted By: robb420in323
Subject: Home amp with Car Sub
Date Posted: February 09, 2005 at 8:27 PM
Hey I have a bedroom with e vintage sound system in it..
I have an 1974 SAE Power Amp that can handle 4Ohms..
I also have a spare JL subwooder in a 6th order Bandpass box.. JL 10WO to be exact.
I want to run that sub in my room..
Does anyone see any problems with that?
What could happen both Negative and Positve!
Keep up the good work guys.
Robb
------------- Hunter S. Thompson for sheriff
Posted By: jeffchilcott
Date Posted: February 09, 2005 at 8:33 PM
postive, you add a little bass in your room. negative, it will sound like butt and you wont like it
------------- 2009 0-1000 Trunk WR 154.0DB 2009 1001+ Trunk WR
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Posted By: Poormanq45
Date Posted: February 09, 2005 at 8:34 PM
It'd work just fine.
The only real difference is that Home stereo equipment is usually higher quality then car stereo equipment. I don't know if this still holds true today though.
If your amp can handle it, hook it up and listen
