could i use this amp with my 12’’brahma
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=49773
Printed Date: May 09, 2026 at 8:31 PM
Topic: could i use this amp with my 12’’brahma
Posted By: alldaz
Subject: could i use this amp with my 12’’brahma
Date Posted: February 10, 2005 at 2:16 AM
https://www.cardomain.com/item/POWA2400DB
I'm planning to get a 12'' brahma, I want to see if I could use this amp or would it fry the sub? I know it isn't a good amp but i've used it for a while and I want to see if I could use it with this driver. What will really happen if I do decide to use this amp, will the sq just not be good or will it just not be loud? Can I have suggestions to a CHEAP amp for this driver that will do the job without frying the sub.
Subwoofer(s): Two(2) 15'' Kole Audio KMX-15's
Amplifier: One(1) Power Acoustik Digital Series 2400A
Headunit: Pioneer 860DEH
Speakers:Factory
Yellow Top Battery
Posted By: kfr01
Date Posted: February 10, 2005 at 3:48 AM
Try it. Just set the gains correctly, don't mess with the bass boost or any crap like that, and don't turn your volume knob past where it was set when the gain was set.
As long as you don't clip the thing like crazy you won't damage it.
Don't run it at 1 ohm to the Brahma. Stick with 4-ohms.
New Project: 2003 Pathfinder
Posted By: blg748
Date Posted: February 10, 2005 at 7:52 AM
Well just take a look at the brahma white paper or the power handling sheet. For 2.1ft^3 ported box a brahma needs only 500Watts. FOr me my plan is to run it witha good 600Wattrs Wrms when i can fidn a brahma.
Kfr01: you think a Phoneix Gold Tantrum T500.2 will be good if i wire the brahma in series for 4 ohm load? the amp puts out a underrated 500WRms @ 4ohms when bridged. Its more l ike 575WRms.... Or should i go inanse and just buy a Pg Tantrum 1200.1 1450WRms @ 4ohms . I like Phoenix Gold so i tend to stick with it.
Posted By: alldaz
Date Posted: February 10, 2005 at 9:09 AM
Thanks kfr01, can I get any more suggestions from you'll. You're the experts here posted_image
Speakers:Factory
Yellow Top Battery
Posted By: thapimpfromchi
Date Posted: February 10, 2005 at 11:49 AM
well how much are you looking to spend on an amp? I'm sure we can give out some pretty nice suggestions that'll fit ur price range.
1990 Honda Civic HB:
Clarion DXZ545MP H.U.
2- 6.5" Power Acoustik interiors
Diamond Audio 600.1 amp
Diamond Audio 15" M6MKII
Pyramid PB881X 4 CH. Amp
Posted By: pimpincavy
That amp should be fine for on brahma. If you end up buying a second one at some point in the future (like you said were going to in your other post) you should also upgrade the amp.
Posted By: uthinkuknoaudio
Date Posted: February 10, 2005 at 5:15 PM
I don't know what that amp is, but the distortion at .5% @ 4 ohms RMS seems a little dangerous... perhaps something with a little better quality? MTX or Hifonics????
"I don't play games. I play Nakamichi and that for real yo" - Probably some japanese kid said this in the early 80's trying to sell stereo out of his trunk lol.
Posted By: Alpine Guy
Date Posted: February 10, 2005 at 8:30 PM
I would look into something a little better to actually match that sub since you have the Ferarri of subs,,,you can't just use a cavalier motor, know what im sayin?
You shouldn't go over 1000wrms, the tech at Adire told me im pushing it on the red line if i put a 12" in 1 cubic foot with 1000wrms.
Posted By: alldaz
Date Posted: February 10, 2005 at 9:20 PM
I'll be using a 4ohm load putting 900 watts into it, no more so it should be fine. Since i'm putting around 900 watts in the the 12'' brahma how any cu feet do you think the box should be? Steve K can I have your input on this too?
Speakers:Factory
Yellow Top Battery
Posted By: alldaz
Date Posted: February 10, 2005 at 9:29 PM
Thats the subwoofer enclosure that Adire offers with the sub. The box is prefab but made exactly to fit the sub.
Single 12" sealed1.25 ft3 x 150 lbs
24.00" wide x 15.00" high x 9.00" top depth x 13.00" x bottom depth
Do you think that enclosure is sufficient enough if i'm runnin a 4ohm load on the driver..it will be recieving 900 watts
Speakers:Factory
Yellow Top Battery
Posted By: alldaz
Date Posted: February 10, 2005 at 9:32 PM
Can't seem to edit last post so here it is restated.
                     VOLUME           WEIGHT                 DIMENSIONS
12''sealed1.25 ft3 x 1   50 lbs
Speakers:Factory
Yellow Top Battery
Date Posted: February 10, 2005 at 9:40 PM
That should be a perfect match up, maybe shrink it an inch or 2 in the width and it should be perfect.
Posted By: alldaz
Date Posted: February 11, 2005 at 10:08 AM
bump
Speakers:Factory
Yellow Top Battery
Posted By: alldaz
Date Posted: February 11, 2005 at 1:56 PM
bump...come on guys more help please.
Speakers:Factory
Yellow Top Battery
