Slotted port box dimensions
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=49894
Printed Date: May 11, 2026 at 8:40 PM
Topic: Slotted port box dimensions
Posted By: xtreamcc
Subject: Slotted port box dimensions
Date Posted: February 11, 2005 at 1:53 PM
Hi all. I need just ur everyday run of the mill dimensions for a slotted 12" subwoofer box. I'm going to put a RFP3812 in it just for experimentation with porting (I'm a FG/sealed box guy and I am in the process of figuring out porting) and push it with either a 400 watt mono or a 200 watt bridged 2 channel amp. Any help would be greatly appreciated.
"Shiny chrome when used in conjunction with bikini models is particularly effective in inducing brain deficit disorder"
02 Jeep Grand Cherokee
Monster System on its way.
Posted By: newtone
Date Posted: February 11, 2005 at 10:22 PM
rule of thumb i use is to have 7.5 in2 for 35hz; 11.25 in2 for 40 hz; 15in2 for 45 hz of port area per ft3 of net box size.  ports 13 inches long
ie:
4 ft3 box would have a port 45 in2 x 13inches long to be tuned at 40 hz
this is ballpark, hope it helps
