1973 mercedes benz 280
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=49903
Printed Date: May 12, 2026 at 12:16 AM
Topic: 1973 mercedes benz 280
Posted By: erimwah
Subject: 1973 mercedes benz 280
Date Posted: February 11, 2005 at 4:19 PM
I have this mercedes benz 280 year 1973 and the audio wiring is kind of all messed up. I have tested the ground and they live wire and they work. The thing is speaker wiring is not the normal one.
I have check the spec from this site which are in contrast with the link here.
https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1973-83&make=Mercedes&model=240/280%20Series&ID=18336&type=Stereo
There is a brown wire which is the ground
There is a black wire which is the live ( battery )
but the wiring in for the speakers ( I think ) are this color
1 gray wire with a red thing in the middle
1 gray wire with a green thing in the middle
1 white wire
1 brown wire
1 white wire
I don't even know where to start testing I know I need a meter to test continuity but at the moment got none.
Any one with any idea what those wires mean I would truly appreciate it.
Thank you very much.
Posted By: kgerry
Date Posted: February 11, 2005 at 10:00 PM
where did you get your speaker wires? this vintage of vehicle may have a separate tuner/amplifier box up by the glove comp...which will have your speaker connections plugged into it....they will be your typical euro dot/dash plugs....
does it have the wheel type fader control at the bottom of the console area?  what model of Becker unit did it come with?
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
