strange noises
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=50453
Printed Date: March 30, 2026 at 1:02 AM
Topic: strange noises
Posted By: dwarren
Subject: strange noises
Date Posted: February 19, 2005 at 4:15 PM
I am hearning a bizarre noise when my system is on and my heater fan is on too. The fan sounds as if it is rubbing something, it is rythmic to the fan rotating, but it sounds more electric than physical. The noise stops as soon as I turn the deck off (the fan goes back to sounding normal). thanks
Posted By: stevdart
Date Posted: February 19, 2005 at 7:26 PM
Sounds like induced noise from the blower unit.  Try to relocate your signal wiring coming out of the deck...possibly just a few inches might stop the induction.
Posted By: dwarren
Date Posted: February 19, 2005 at 8:00 PM
I hope so, it is a bit of a mess back there though, the deck has an external dc-dc converter, could that produce more induction. thanks
Posted By: stevdart
Date Posted: February 19, 2005 at 8:04 PM
I don't believe so.  I think the blower unit is creating a magnetic field that the signal wires pass through.  It sounds like it's coming from the fan (because the noise is the same freq as the fan) but is coming from the front speakers instead, which play that freq level.  Or, the signal wires are running parallel with the wiring that feeds the blower.
Posted By: wayland1985
Date Posted: February 20, 2005 at 7:27 PM
Does sound like you need to move the wires around a bit. I had a similar problem, only it was the Vehicle's Computer that was causing the noise. Re-routing the cables a few inches away solved the problem.
If space is an issue for working back there, consider removing parts in the dash, like the climate control, or remove the entire dash itself. It can be frustrating, but at least you'll have better access to re-organize the wires.
~WAYLAND
Posted By: soundmasta
Date Posted: February 21, 2005 at 7:58 AM
aliens.
Posted By: oonikfraleyoo
Date Posted: February 21, 2005 at 8:05 AM
I agree soundmasta. They have moved into your dash and the sounds have something to do with their evil plans to destroy the human race and take over the world. I'm sorry to say but I don't even know if your local car audio superhero can save us now.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
Date Posted: February 22, 2005 at 7:11 AM
even troubleshoting can't help now!!
