grounding?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=5100
Printed Date: April 18, 2026 at 6:41 PM
Topic: grounding?
Posted By: 01redgsr
Subject: grounding?
Date Posted: November 03, 2002 at 8:43 PM
anyone ever hear of a grounding post?? If so should i use one to ground my amp and cap or just ground it to the body somewhere? What does everyone else use to ground to?
------------- 2001 Milano Red Acura Integra GS-R
1 12" JL Audio 12w6v2
1 JL Audio 500/1 Amp
1 Farad Cap by Lightning Audio
Posted By: abright52
Date Posted: November 03, 2002 at 10:27 PM
I usually ground to my body. Take some sandpaper and get the paint off of the place you are mounting to and then drive a screw into that spot (Be sure that you are not going to hit anything on the other side). I usually attach the ground wire with a ring terminal and drive the screw through the ring with a washer, so that everything is tight and has a solid connection.
Posted By: 91blaze
Date Posted: November 04, 2002 at 11:44 PM
i take my ground straight to the frame. i grind down to bare metal, bolt a ring terminal on, silicone around it and coat it.
