line drivers ?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=51119
Printed Date: April 17, 2026 at 10:44 AM
Topic: line drivers ?
Posted By: gbody805
Subject: line drivers ?
Date Posted: March 01, 2005 at 9:19 PM
 I wanted to know what the senior members thoughts are on line drivers for multiple amps.
 I have several amps, I've BI-amped alot of my system. With the kenwood HU I have it is only puttng out 2000mV.
 My question is would a line driver help me get a good signal to my amps?
1980 monte carlo
kenwood KDC-X579
Polk audio in Kick panels
3.5 coaxials in dash
6.5 midbass in doors
8"in rear side panels
4X10 in rear deck
3 12s in trunk
Harmon kardon X-over 6way
6 amps
Posted By: Ravendarat
Date Posted: March 01, 2005 at 9:22 PM
A line driver will most definatly give you a stronger signal to your amps and if you are running several amps off one set of preouts then I definatly recomend them. I personally have not run a system in almost 4 years now that didnt contain either my audiocontrol 3.1 or my pheniox gold PLD1.
Posted By: haemphyst
Date Posted: March 02, 2005 at 12:12 AM
OK, go for it, BUT keep in mind you are adding noise, distorion, and non-linearities to your system. You also run the risk of overdriving the amplifier inputs, which adds further distortions, and compromises the reliability of your system. If you set your gains on your amps correctly, and use quality matched components, you will not need a line driver. I have NEVER used one, and I have always been able to get enough noise to be satisfactory.
