Help with amp cutting off
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=51349
Printed Date: April 17, 2026 at 11:12 AM
Topic: Help with amp cutting off
Posted By: phu615
Subject: Help with amp cutting off
Date Posted: March 05, 2005 at 2:30 PM
I have another account but it wont let me log on so i had to make another account. My problem is that my 4 channel amp, when i turn the music up it sounds like it is grounding and it gets very distorted. If i turn it up to 15 on my alpine deck, it cuts off/ shuts off. It never cut off before and when my soundstream 10.0 turns on for a second and turns off.  The only way i can get the soundstream amp to stay on is to connect the remote to the positive.
crossfire 4 channel- cuts off and is very distorted
soundstream mono- turns on for a second.
Weak remote? I checked it and tried another remote to see if it was grounding and that wasnt it.
I have tried everything i can think and it have had no luck.
Posted By: phu615
Date Posted: March 05, 2005 at 2:33 PM
I also have a cap and i thought that could be a problem, but it didnt help either.
Posted By: DYohn
Date Posted: March 05, 2005 at 2:45 PM
What's the load on each amp?  How did you set your gains? Are your grounds good?  Do yu have enough power from the alternator to keep the voltage up?
