sony xplod 760W amp?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=51410
Printed Date: April 18, 2026 at 6:26 PM
Topic: sony xplod 760W amp?
Posted By: ymichael156
Subject: sony xplod 760W amp?
Date Posted: March 06, 2005 at 1:03 PM
whas goin on everyone? I have a problem...when i turn on my system, it will thump for about 5-10 min, then the over current light comes on and shuts off the bass output. now I am wondering if this pertains to the current from the battery or the way i have my subs wired, i have them wired 2ohm, (sony xplod 800W max each). does anyone know how i can fix this problem??
Posted By: byrumjr
Date Posted: March 06, 2005 at 1:33 PM
Sounds like the way you have your subs wired to the amp and it's getting to hot and cutting out. Try running them at 2 ohms and just hook it to one channel or bridge one sub at 4ohms.
Posted By: oonikfraleyoo
Date Posted: March 06, 2005 at 1:52 PM
You could also try a descent amp.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
Posted By: MrSector9
Date Posted: March 06, 2005 at 1:55 PM
Yeah a guy locally had i think it was 6 of those amps,bought 1 and the rest were covered under warranty.He had a shop instlal it the first tiem so in no way (well maybe they screwed up) that he screwed u the wiring.Every couple weeks it owudl just cook itself.
BJ white
Date Posted: March 06, 2005 at 2:55 PM
thanks for the input guys. ill go try this and see what happens.
Posted By: DYohn
Date Posted: March 06, 2005 at 3:25 PM
Is your amp mono or stereo/  What's the model number?
Date Posted: March 06, 2005 at 5:18 PM
Its a 1/2 channel stero amp, and the model number is XM-2150GSX...but I think I have solved the problem. I put the subs which are on a 2ohm wiring setup, on one channel...which in the other case before I had it on both channels. its hitting hard and fine now, but if there is anything else I can do, I will gladly accept input.
Posted By: DYohn
Date Posted: March 06, 2005 at 5:28 PM
Assuming the subs are 4-ohms each, wire one to each channel of the amp.
Date Posted: March 06, 2005 at 5:57 PM
Alright cool. I'll try this. Will this allow me to get lower dBs than I have now with it wired as 2ohm?
Date Posted: March 07, 2005 at 3:12 PM
Maybe I should have asked if this is better than wiring it to one channel as 2ohm. Is it???
Posted By: Ravendarat
Date Posted: March 07, 2005 at 5:05 PM
2 ohms to one side is no different then 4 ohms to both sides
Posted By: DYohn
Date Posted: March 07, 2005 at 5:10 PM
The only difference is it will stress the amp less to utilize both channels.  The amp will run cleaner, cooler and last longer running at 4-ohms per channel.  This can be very important with Sony Xplod(ing) amplifiers.
Posted By: Jay22
Date Posted: March 07, 2005 at 5:53 PM
OK your amp is not 2 ohm stable MONO only 2 ohm stable stereo.....so you have to run it either 8 ohms bridged(MONO) or each sub to seperete channels stereo....It will be the same.....so you should either buy new subs DVC 4 ohms or buy a 2 ohm stable bridged amp.....
I had the same problem when I bought my first system like 4 years ago and knew nothing know I know what to look for and have been thru plenty of stereos...
Jay
