door removel
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=51542
Printed Date: April 12, 2026 at 9:19 PM
Topic: door removel
Posted By: ksutton
Subject: door removel
Date Posted: March 08, 2005 at 3:01 PM
does any one know how to remove a door on a 01 buick le sabre.
Posted By: skoldspuppy
Date Posted: March 08, 2005 at 3:10 PM
With or without explosive charges? sorry I couldnt resist I was out shooting a 50 cal this weekend No really pull off the interior panels just like any other door and disconnect the wiring from the entire door, open the door and you should have 2 hinges 1 at the top of the door and 1 at the bottom, they both should have 4 bolts attaching it to the frame of the car, Id use a floor jack under the door to take off the pressure of the weight of the door Follow instructions in reverse order to install, if you unsure take it to a repair shop Later --Skold ------------- 2004 Honda Civic Ex 4Dr
Kenwood DDX-7015/W Nav
4 Fosgate T152C
Hifonics Brutus BX1500D
RE XXX 12 in a 4 Cube Snail Shell
Posted By: auex
Date Posted: March 08, 2005 at 3:43 PM
Open said door, throw car in reverse, hit the gas, wait till you hit something with the door, and said door will be removed. Note you did say DOOR!
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: Alpine Guy
Date Posted: March 08, 2005 at 5:36 PM
haha, , my co installer did that to a 99 CLK 430 benz....
------------- 2003 Chevy Avalanche,Eclipse CD7000,Morel Elate 5,Adire Extremis,Alpine PDX-4.150, 15" TC-3000, 2 Alpine PDX-1.1000, 470Amp HO Alt.
Posted By: forbidden
Date Posted: March 08, 2005 at 6:43 PM
I think that 50 cal would make short order out of pretty much any door. What on earth were you doing and where on earth would you have access to such high powered weaponry? Oh yeah, about the door..... Open it on a busy downtown street, some idiot on a cell phone will take care of the rest. We don't really get those vehicles here in truck country, if we did I would gladly post some pertinent info for you.
------------- Top Secret, I can tell you but then my wife will kill me.
Date Posted: March 08, 2005 at 7:27 PM
If you must know a friend of mine who used to be ex cop has a Import/export of firearms all you need is a Type 11 ATF licence "IMPORTER OF DESTRUCTIVE DEVICES, AMMUNITION FOR DESTRUCTIVE DEVICES OR ARMOR PIERCING AMMUNITION" it runs you about $3,000 every 3 years and well worth it We were just testing a Barrett M107 out on some conceret walls and an old ford pinto out here in the everglades, if your ever in florida let me know we'll go shooting sometime. Later --Skold ------------- 2004 Honda Civic Ex 4Dr
4 Fosgate T152C
Posted By: geepherder
Date Posted: March 08, 2005 at 10:08 PM
First, remove the door panel and disconnect the wiring. Try to pop the molex plugs loose and see if the harnesses can fit through. To remove the door, you should first undo the door stop. Open the door, and unbolt the little doodad. You'll probably have to remove the fender to get to the hinges. ------------- My ex once told me I have a perfect face for radio.
Posted By: oonikfraleyoo
Date Posted: March 08, 2005 at 11:10 PM
My uncle works at the Barrett factory. I have one. In Alabama you need no special licence though I have a class 3 manufacturer's licence. If you drive down here, I'll take care of that door. ------------- Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
