motorized antenna problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=51634
Printed Date: April 09, 2026 at 8:50 PM
Topic: motorized antenna problem
Posted By: msf145
Subject: motorized antenna problem
Date Posted: March 09, 2005 at 6:22 PM
I have a 97 mitsubishi eclipse. it has a motorized antenna that keeps breaking on me. it will get stuck and not come down. so i decided to get a traditional "whip" antenna.
i took the motor and antenna out and put the new whip antenna in. but now the radio wont turn on. i then cut the wire to the power antenna lead on the radio but that didnt help.
so i put the old motor and old antenna back in and now the radio works. very strange...
the next thing i did was keep the motor in with the power connections and ground but unplugged the old antenna and plugged the new antenna back in. the radio doesn't work.
it seems that the radio wont turn on unless the motor and old antenna are plugged in.
is there anyway to get around this? id appreciate any help with this.
Posted By: Ween
Date Posted: March 09, 2005 at 6:53 PM
the radio is grounding through the antenna coax lead, when you unplug it, no ground......no radio.  try mounting the whip antenna properly into the fender, not spoiler, and try again.
mark
Posted By: msf145
Date Posted: March 09, 2005 at 9:17 PM
thanks for you help. thats what it was. i sodered a wire to the antenna and grounded the wire. now it works. thanks alot!
