A -Pillar Components
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=51749
Printed Date: April 07, 2026 at 4:43 PM
Topic: A -Pillar Components
Posted By: oonikfraleyoo
Subject: A -Pillar Components
Date Posted: March 11, 2005 at 12:51 PM
I am gonna be doing some work for a guy in a 63 Impala. He wants me to put screens and his 6.5" components into the A-Pillar. This car won't be driven, so the obvious vision obscurment won't be a problem. I know I can make it look good, and it seems like as far as aiming them this would be a good place to put 'em. Does anyone see any down side to putting the components in the A-Pillars?
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
Posted By: dwarren
Date Posted: March 11, 2005 at 1:05 PM
are you going to mount the mid bass in the A pillar too? It sounds like you are jsut putting the tweeter there which may cause imaging problems.
Date Posted: March 11, 2005 at 1:08 PM
One 6.5 and one tweeter under a 7" monitor. I know it sounds strange but I'm sure I can make it look good.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
Posted By: auex
Date Posted: March 11, 2005 at 1:12 PM
Other then how it will sound, No. Aiming is easy but one speaker will be 2 feet from your head and the other one will be 4-5 feet from your head. Has it been done, sure.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: March 11, 2005 at 1:15 PM
But how would that be any different than if they were in the doors? They would be almost the same distance from your head.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
Posted By: DYohn
Date Posted: March 11, 2005 at 1:45 PM
The A-pillar places the left speakers far closer to your ear than any door mounting could.  Use 4-ohm speakers and add a 2- ohms resister in series and a 4-ohms resister in parallel (a 6db attenutation circuit) to the left side crossover network  - especially for the tweeter - to knock it down if you want the sound to be closer to correct at the driver's position.
Posted By: forbidden
Date Posted: March 11, 2005 at 6:05 PM
You need to go to this site and ask Dave for his input. I am MR2NR on that forum.
https://www.canadiancaraudio.com/ubb/ultimatebb.php?ubb=get_topic;f=3;t=010212;p=1
Posted By: stevdart
Date Posted: March 11, 2005 at 6:21 PM
DYohn, you're describing an L-pad, right?  Does it go just prior to the speaker or does it go before the crossover network?
Posted By: DYohn
Date Posted: March 11, 2005 at 7:38 PM
Yea, it can be an L-pad, which is usually variable and can be a better solution if you don't know how much attenuation you need.  What I described is simple a fixed value resistive pad.  They can be used anywhere in the speaker-level signal chain.
Date Posted: March 11, 2005 at 8:24 PM
Thanks DYohn. I'll give that a shot. This isn't exactly a SQ car. The guy just wants it for show, but I don't wanna put my name on anything thats gonna sound like arse. This car is huge and at the lowest level that I can put the speakers they will be close to 3 feet from your head.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
