poor sound from aftermarket 96 intrepid
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=51879
Printed Date: March 29, 2026 at 3:22 PM
Topic: poor sound from aftermarket 96 intrepid
Posted By: inhissirvice
Subject: poor sound from aftermarket 96 intrepid
Date Posted: March 13, 2005 at 7:34 PM
96 intrepid basic amfm cassette standard
6 speakers, 2 in dash, 2 in doors, 2 in rear deck
installed Jensen cm9521 200 watt
I have been all over the forum and seen a lot of posts that were close but not a "final" fix.
symptom: poor sound quality no base response, no sound at all from door speakers
speaker continuity reads 5000 ohms -- is this for real?
is there an amp in this basic sound system?
I have tried the unit power antenna wire to the blue/white wire -- nothing
any help would be appreciated?
thanks
Jack
Jack 96 white intrepid 3.3
Posted By: geepherder
Date Posted: March 13, 2005 at 10:00 PM
When you pulled the factory unit, did you have a wire with a female spade connected to the back of the radio?  If so, this is the amp ground.  Connect it directly to ground, and let us know if that solves it.
Posted By: oonikfraleyoo
Date Posted: March 13, 2005 at 11:18 PM
Where did you take that ohm reading from? Right behind the HU? Or at the speakers themselves?
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
Date Posted: March 14, 2005 at 3:05 PM
I TOOK THE READING AT  THE STOCK CONNECTOR COMING FROM THE DASH THAT PLUGS INTO BACK OF HU.
THANKS FOR YOUR HELP
Date Posted: March 14, 2005 at 7:33 PM
I'm thinking that your reading the impedance of the factory amp. Not sure, just a thought.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
