Speaker wiring question
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=52198
Printed Date: March 09, 2026 at 9:24 PM
Topic: Speaker wiring question
Posted By: morgs
Subject: Speaker wiring question
Date Posted: March 19, 2005 at 9:43 PM
I'm wiring 1 set of speakers to a new stereo in a boat. The speakers can hold a max of 150w each, my stereo is 50w x 4. If I wire it AS IS I'm only going to get 50w going to each of the two speakers. If I'm just going to have the one set of speakers installed can I run both the front and rear wires coming out of the receiver to each of the two speakers. Essentially turning the 50w x 4 into 100w x 2.
Front L + Rear L to one speaker Front R + Rear R to the other speaker Thanks -Morgs
Posted By: projectprotege
Date Posted: March 19, 2005 at 10:03 PM
whats the specs on the deck? usually you cant bridge the cd deck like that unless it is stated on the box. plus i dont think ive really seen a radio that caqn throw more then like 15-30 watts. but then again i could be wrong, ive also read on some website that a guy ran a test and he hasnt seen a radio throw more then 15-30 even though they stated 50w....im going to try and find that site. but if im wrong im sorry....
Posted By: Alpine Guy
Date Posted: March 19, 2005 at 10:05 PM
NO, you cannot do that, you will fry your head unit. Don't look at max power rateings, they mean nothing, ,look at RMS rateings. Your headunit will be around 18 watts rms each channel.
------------- 2003 Chevy Avalanche,Eclipse CD7000,Morel Elate 5,Adire Extremis,Alpine PDX-4.150, 15" TC-3000, 2 Alpine PDX-1.1000, 470Amp HO Alt.
Date Posted: March 19, 2005 at 10:07 PM
"2. If you are planning on using the built-in amplifier of the new deck, get one rated at 40 Watts x 4 or higher. It really only produces 15-25 Watts but this is much better than the older >35 Watt models."
https://bmw_jeff.home.att.net/deck.html
