What is going on with this system?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=52499
Printed Date: April 14, 2026 at 8:10 AM
Topic: What is going on with this system?
Posted By: Lubuspl
Subject: What is going on with this system?
Date Posted: March 24, 2005 at 9:52 AM
I installed this system maybe 3 weeks ago. It worked fine for about a week and a half.
Then the person who I installed it for took it out and somehow when he connected the amp back the amp was not reading the ground (when you tested the ground it has a positive power give off). At this time I changed the ground to a different place and the system worked fine for about another week or so.
Now the fuse by the battery broke, and I changed it. The next day it broke again, should I get another fuse and try again or should I just send this Sony 1600 watt amp to their crappy factory.
Anyone any idea?
Posted By: SoundExplosion
Date Posted: March 24, 2005 at 10:20 AM
What gauge power wire are you using ? and what size fuse  do you have inline to the amp at the batt. ?
SoundExplosion
"You are only as good as your last install"
" T-taps should never be used"
Posted By: Lubuspl
Date Posted: March 24, 2005 at 10:35 AM
Its a 8 gauge power wire and I am not sure what size it the fuse but it came with the kit and I replaced it with the same one or even a little stronger from the store. (its one of the thick ones not the tiny one)
Posted By: Francious70
Date Posted: March 24, 2005 at 11:24 AM
Wasn't this the exact same question that was asked last week??
Either way, the amp is bad.
Paul
Posted By: DYohn
Date Posted: March 24, 2005 at 12:09 PM
DON'T BE A FOOL.  NEVER simply keep replacing fuses!!  A fuse is there for a reason: to keep your car from going up in flames.  If one is blowing, find out why and FIX the problem before you simply keep replacing it.  BASIC electrical safety.
If you do not understand what is going on with the system take it to a shop and get some help.
Posted By: KarTuneMan
Date Posted: March 24, 2005 at 12:56 PM
your  amp is toast.....too small guage power wire won't cause the amp ground to show voltage.....its an internal problm. And yes, even for that little "1600 watt" sony....8 guage is too small!
Posted By: specialauto
Date Posted: April 11, 2005 at 10:04 AM
all i have to say... is sony is junkposted_image big shocker there
Canadian Auto Sound
Starting Installer
