what amps 2 buy for setup
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=52523
Printed Date: April 17, 2026 at 11:11 AM
Topic: what amps 2 buy for setup
Posted By: ocboy79
Subject: what amps 2 buy for setup
Date Posted: March 24, 2005 at 5:38 PM
Hey guys I am requesting the assistance of the pros out there. I have 16 pioneer ts-w250r 10's. they have a single voice coil, are 4ohms, have a rms of 120 and a max of 500w. i have them in sets of 4. so 4 are in a box. i want to be able to put one amp for each box.(thats 4 10's to one amp). can you guys give me some good size amps that will power each set but not overload the speakers. thanks for your help.
------------- panasonic-8300
16- pioneer ts-w250r
boston 6x9
Posted By: ocboy79
Date Posted: March 24, 2005 at 6:03 PM
also the amps need to have a line out so i can connect them together, unless yall have a better idea.
boston 6x9
Posted By: uthinkuknoaudio
Date Posted: March 24, 2005 at 6:12 PM
Cadence ZRS-9. It can pull that load all day long. You can get 2 of them and get the bridge cable and get 4000 Wx1 @ 1 ohm RMS. Not bad. They are great amps.
------------- "I don't play games. I play Nakamichi and that for real yo" - Probably some japanese kid said this in the early 80's trying to sell stereo out of his trunk lol.
Posted By: kfr01
Date Posted: March 24, 2005 at 6:14 PM
You are obviously concerned about SPL over sound quality. For the most bang for the buck you'll want to look for class d mono blocks that are 1-ohm stable.
Here's a good value: https://www.memphiscaraudio.com/products/details.asp?cat=&id=98&p=2
------------- New Project: 2003 Pathfinder
Posted By: ocboy79
Date Posted: March 24, 2005 at 6:20 PM
ok but how would i get the ohms down to 1ohm. also how much the the cadence ZRS-9? one person i talked to told me to get visonik 1100 2 channel ( 4 of them) thats what i want to do is get 4 separate amps instead of 2 big ones
boston 6x9
Posted By: ocboy79
Date Posted: March 24, 2005 at 6:22 PM
i really dont want to go with 2 big amps. how about 4 mid-sized amps. but how much for that cadence?
boston 6x9
Date Posted: March 24, 2005 at 8:35 PM
The Cadence is a very large amp, but you'll only need two and you'll cut down on the space that you would need for 4, as well as the amperage and connections. You'll save more you'll find out. I know you can get 2 of them for a grand. Let me know, i have a friend who is a private professional dealer. PM me.
Posted By: ocboy79
Date Posted: March 24, 2005 at 11:02 PM
well see space is not a problem. i have a old school station wagon. plus i dont want 2 spend that much.
boston 6x9
Posted By: oonikfraleyoo
Date Posted: March 25, 2005 at 9:31 AM
You are most likely gonna spend more on 4 medium amps than 2 large amps. ------------- Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
Posted By: DYohn
Date Posted: March 25, 2005 at 9:41 AM
And DONT buy Visonik if you want it to last and sound decent. The Memphis amp suggested above is a killer choice. How much DO you want to spend? ------------- Support the12volt.com
Posted By: ocboy79
Date Posted: March 25, 2005 at 2:10 PM
well now that i think about it price really doesnt matter, but not more than $700 dollars an amp.
boston 6x9
Posted By: DYohn
Date Posted: March 25, 2005 at 4:15 PM
OK, so you have four sub enclosures, each with 4 SVC 4-ohm 125 watt RMS woofers, right? Assuming you want max output (what else with that many subs?) you can either run one 500 watt mono @ 4-ohms (or 500 watts @ 1 ohm) amp for each enclosure, two 1000 watts @ 2-ohms amps, or one 2000 watts @ 1-ohm amp. One amplifier is easier to set up and much cheaper in the long run. That's what I recomend. If you are serious about having $2800 to spend on amps, there are some really nice options out there for you from Xtant, JBL, Zapco, Phoenix Gold, Eclipse... walk into any car audio shop anywhere and tell them you want 2000 watts @ 1-ohm of the best, cleanest, high-end class D subwoofer amp they have and that you have $2800 to spend and you will certainly find people ready to help you out!! They'll probably install it for you too. Next thing to consider is how are you planning to power this beastly setup? I hope you have a very good high-output alternator... ------------- Support the12volt.com
Posted By: ocboy79
Date Posted: March 26, 2005 at 5:00 AM
well right now i have a optima yellow top battery and a stock alt. but i have 4 10's hooked up 2 a 4 channel sony xplode 800 watt amp and my amp gauge pulls badd. i want 2 go with another yellow top and a high amp alt but i dont know how much or where i can go to get it. or i was thinkin about 2 alts. but i would need a braket made and i dont know ehrer to get that either. also if i get one 2000 watt amp would that be for all 16? what brands do u recomend? ------------- panasonic-8300
boston 6x9
