'91 nissan maxima stereo wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=52704
Printed Date: March 30, 2026 at 9:39 AM
Topic: '91 nissan maxima stereo wiring
Posted By: Max2000
Subject: '91 nissan maxima stereo wiring
Date Posted: March 27, 2005 at 9:57 PM
I jus purchased a '91 4DR nissan maxima. i was wondering does anybody kno where i can get a diagram with the original wire colors or jus the orignal wiring ... im going to install a kd-ar260 made by jvc since the car was purchased without a radio.. can someone pls help me out..
Posted By: auex
Date Posted: March 27, 2005 at 10:18 PM
You could try the diagram section of the site? Click here.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: Max2000
Date Posted: March 27, 2005 at 10:34 PM
thanks.. i dont kno y i didnt see that.
Posted By: Max2000
Date Posted: March 27, 2005 at 11:26 PM
also if any of u have any other information it would be most appreciated.. thank u
Posted By: oonikfraleyoo
Date Posted: March 27, 2005 at 11:54 PM
What other info do you need?
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
Posted By: Chad7n7
Date Posted: March 28, 2005 at 6:06 PM
First of all, by requesting that diagram, it looks that you are about to cut the factory wiring, or it has been cut. If it has already been cut, then carry on.
If you still have the factory harness in tact, then don't cut it, go down to your local stereo shop and get an aftermarket harness to wire up your HU. Easiest solution.
Posted By: MrSector9
Date Posted: March 28, 2005 at 8:30 PM
Check out www.maxima.org on the forums... HUGE amount of information for all gens of maxima..
BJ White
1992 Maxima SE Black on Black :)
