Wiring questions
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=52841
Printed Date: April 02, 2026 at 7:42 PM
Topic: Wiring questions
Posted By: akuterrer
Subject: Wiring questions
Date Posted: March 30, 2005 at 9:13 AM
Hi Guys, I'm new here. I'd like to know between the battery and the HU, what is the capacity of the fuse needed? I'm currently also facing some choppy sounds when engine is turned on but sound is smooth when engine is turned off.What could be the possible reason of this problem? Any help is greatly appreciated. Thanks!
Posted By: DYohn
Date Posted: March 30, 2005 at 9:52 AM
Hi there. This is probably not the answer you want, but it depends on the head unit. The maximum current draw should be in your owner's manual. As to the second question, what do you mean by "choppy sound?" Also please let us know what pieces are in your system (make/model, etc.) ------------- Support the12volt.com
Date Posted: March 30, 2005 at 12:14 PM
Hi, My HU is a Pioneer DEH 3350.I don't have a manual as I got it 2nd hand.You got this model's manual? Regarding the choppy sound, it doesn't sound smooth. The sound is like cracking up.Sound is only smooth when engine is off. This problem only occurs recently. Previously sound was great.
Posted By: DYohn
Date Posted: March 30, 2005 at 2:00 PM
If it's available, you can download it from Pioneer. Sound cracking up. Do you mean it cuts in and out? Is there an amp in your system? ------------- Support the12volt.com
Date Posted: March 31, 2005 at 3:58 AM
Yup its from Pioneer. Thanks for the link but can't find the manual though. Its a Pioneer DEH-P3350 There's no AMP in my system. Here's a link of the diagram how I connect my system.
Posted By: geepherder
Date Posted: March 31, 2005 at 7:21 AM
I'd start with a 10 amp fuse.
------------- My ex once told me I have a perfect face for radio.
Date Posted: March 31, 2005 at 8:08 AM
Date Posted: March 31, 2005 at 10:26 PM
It looks like a 10 amp fuse to me: https://sg.pg.photos.yahoo.com/ph/akuterrer80/detail?.dir=3d71&.dnm=1454.jpg&.src=ph ------------- My ex once told me I have a perfect face for radio.
Date Posted: April 01, 2005 at 3:31 AM
Oops..sorry tht was the pic of my HU. Here's the link to the circuit diagram on how I set up my system. Guess will need a 10Amp fuse also in between the battery and Hu? Thanks again.
Date Posted: April 06, 2005 at 3:05 AM
A thought just hits me, Does bad grounding gives this kind of problem? It only occurs when engine is on but when its off, sound is very good.
Date Posted: April 10, 2005 at 2:10 AM
Hi Guys, I've managed to isolate the problem. Playing of CDs are smooth once I remove the antenna from the HU. Might be due to the antenna wires as I added wires to it to lengthen it. I'll try to rewire the antenna and see how it goes from there. Thanks alot guys for the great help here!
