Speaker replacement 2001 Dakota
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=53098
Printed Date: April 09, 2026 at 1:50 PM
Topic: Speaker replacement 2001 Dakota
Posted By: brooks22
Subject: Speaker replacement 2001 Dakota
Date Posted: April 02, 2005 at 10:13 PM
I very recently purchased a 2001 Dakota xcab with the Infinity sound system from the factory, or so I was told. Someone has replaced the speakers with Alpine SPR-17LS component (70 watts RMS) in the doors and SPR-17LP (50 watts RMS) in the rear panels. These speakers are still available for purchase so they have to be pretty new. The HU is the factory unit. I found, under the back seat, the Alpine crossovers still in plastic. I removed door panel to see if there were crossovers in the door, none to be found, I don't even know if there are supposed to be any. The situation is this, the tweets do not work with the exception of a crackle once in a while. The 2-ways in the rear panels sound like they are barely working. I pulled all of the panels and the speakers are wired, I am assuming correctly. The questions I have are this:
1. Does this vehicle have crossovers from the factory? If so, where would they be? If not, should the Alpine crossovers be installed because they are part of the component set?
2. Could the speakers be wired incorrectly or maybe the HU is going bad?
Any opinions or advise would be greatly appreciated.
Brooks
Posted By: kfr01
Date Posted: April 02, 2005 at 11:42 PM
1) If the real crossovers to any component set are available, they should be used. (Unless you have a customer xo for those speakers or are going active).
2) Could be. :-) I'd take it to an installer. They can probably diagnose it pretty quickly. Part of my reason for replying here is to /bump the post. :) Maybe someone else has some specific information about that vehicle.
New Project: 2003 Pathfinder
