SoloBaric L7 and KX1200.1 Amp Hookup
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=53208
Printed Date: March 31, 2026 at 12:33 AM
Topic: SoloBaric L7 and KX1200.1 Amp Hookup
Posted By: glowstickninja
Subject: SoloBaric L7 and KX1200.1 Amp Hookup
Date Posted: April 04, 2005 at 11:35 AM
Ok so.....I Need some technical advice. I will be buying a kicker L7 solobaric and their new kx1200.1 mono amp. Should I bu the sub in the DVC 2 Ohm version or the DVC 4 Ohm version. I know that running the dvc 4 Ohm in parralle l will yield a 2 ohm load on the amp. so that means if i run the DVC 2 Ohm in parrallel i will get 1 Ohm load on the amp. the specs on the amp are 1200 X 1 rms @ 1 ohm, 600 X 1 rms @ 2 ohm, and 300 X 1 rms @ 4 ohm. The specs on the 2 ohm sub are....total peak handling 1500 watts max. 75-750 watts rms(375 watts per coil). So all this being said here's my question: If i were to hook it up under a 1 ohm load that would mean that i was running 1200 X 1 rms @ 1 ohm (600 wats to each coil right?) wouldn't that be too much power for one sub?
Posted By: Sancho
Date Posted: April 04, 2005 at 1:27 PM
L7 defently will handle 1200 watts without problem
Head Unit:Alpine CDA 9835
6.5 MB Quart Pce 210
Amp:JBL 80.4
Amp:JBL 1200.1
Sub:Adire Brahma 12 MKII
Posted By: racer427
Date Posted: April 04, 2005 at 6:12 PM
You might want to run a dual 4 ohm sub just for the fact that at 2@ you will still be pushing a good amout of power and you will not be working the amp as hard.
  Chris
Alpine CDA-9833 HU
Diamond Audio M661 Components
MTX Thunder T6.6 Components:rear fill:
Cadence Q400 4 Channel Mains + rears
Thunder 801D Subs
MTX 1004 10's
Dual 4g wire to rear
4g grounds
Posted By: racer427
Date Posted: April 04, 2005 at 6:53 PM
Plus at a 2@ load the amp's THD ratings are at 1.5%, add that to a solobaric that already isn't the best for SQ and U have a pretty crappy sounding sub. Drop it to 1omh and the THD will go up!
 Chris
Alpine CDA-9833 HU
Thunder 801D Subs
MTX 1004 10's
4g grounds
