Why do speakers crackil?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=53256
Printed Date: March 30, 2026 at 1:11 AM
Topic: Why do speakers crackil?
Posted By: dece870717
Subject: Why do speakers crackil?
Date Posted: April 04, 2005 at 8:53 PM
whenever i turn on my blinker,car changes gears,braking/decelerating,accelerating, my speakers crackil you hear music but it gets quiet and you hear this crackiling noise for about 2 seconds.doesnt happen when i keep a constant speed though. every part of my audio system is new had it for a few days now. HERES MY STUFF I HAVE...
have these rear speakers https://www.crutchfield.com/S-TA0dZn...00&I=500SPR69LP
front speakers https://www.crutchfield.com/S-TA0dZn...000&I=158XS1635
my amp https://www.crutchfield.com/S-TA0dZn...=120&I=489AP740
speaker wire i use https://www.crutchfield.com/S-TA0dZn...50600&I=211SC16
this wiring kit https://cgi.ebay.com/dl...5763978767&rd=1
Date Posted: April 04, 2005 at 8:59 PM
Posted By: Francious70
Date Posted: April 04, 2005 at 10:28 PM
Check for a ground loop or a speaker wire that's: Pinched, cut, grounding.
Paul
Posted By: Satkunas
Date Posted: April 04, 2005 at 11:49 PM
You mentioned that this happens when you turn on your turn-signal. Is this only when you turn on your signal and you deaccellerate (or accellerate), or does it also happen when you use the signal while motionless?
Is the sound a continuous crackle, or is it just a pop? If it's a pop does it happen when you step on the brake, or turn on the headlights?
If this only happen when you accelerate or deaccelerate does it also do it when you go over bumps at a constant speed? If so does this happen when you slam or open the doors abruptly?
Also tell me what speaker the crackling comes from? Just the front or rear, or all 4. Also tell me what the headunit is running (front speakers), and what the amplifier is running (rear speakers).
Posted By: oonikfraleyoo
Date Posted: April 04, 2005 at 11:52 PM
Is it more likely to happen on a weekend or does it just happen on business days?posted_image
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
Posted By: Satkunas
Date Posted: April 04, 2005 at 11:54 PM
Probably on weekends. I don't know many that cruise on business days posted_image
