Setting the gain
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=53311
Printed Date: March 28, 2026 at 10:05 PM
Topic: Setting the gain
Posted By: boardinbum
Subject: Setting the gain
Date Posted: April 05, 2005 at 1:59 PM
Quick question about setting the gain on my sub's amp.I followed the instructions from DYohn here.But I'm not sure how I'm supposed to have everything set up.Should I turn the bass boost on my amp all the way off or leave it how I usually have it while listen to music?Same with the HU. Should I just leave all the bass settings on it the same way I have them when I'm listening to it?
Posted By: tcss
Date Posted: April 05, 2005 at 6:25 PM
I usually like to turn off all the bass boosting settings on the HU. As far as the boost on the amp, put in a cd you're very familiar with and play with the boost. There is really no "correct" setting. As long as the woofer does'nt bottom out, set it where you like the sound the best.
